Login Error
Close
How to Frame a House
by DoItYourself Staff
When you frame a house you are laying out the skeleton form of the house, including the walls, ceilings and roof. Properly framing a house will require additional assistance and is a labor-intensive task. Careful attention to details and measurements is also important to ensure that the framing structure is strong and well constructed.
Understand the Building Code
Before undertaking a house-framing task, be sure that you thoroughly understand the building code for your area and apply for all necessary permits. The local building inspector must sign off on the framing work before any other construction can take place, including electrical, ductwork, plumbing or dry walling. Failing to understand the nuances of your local building code will cause delays, potential fines or a stop-work order, which will cost you money.
Obtain Resources on Framing
Many books and online resources are available to assist you with your framing project. Look for resources that include step-by-step instructions and photos that demonstrate the progress you should be making at each step. Your local home improvement center is another valuable resource and may even hold classes on framing. If you have never framed a house before, it is highly recommended that you attend a class.
 forum activity
