How to Get Latex Paint out of Carpet
what you'll need
- Sponge
- Washcloth
- Cold water
- Warm water
- Dishwashing detergent
- Paint remover
- Shop vac
Difficulty:The novice can do this.
Time:About a half hour on an average size spill.
If you spilled latex paint on a carpet, you're probably wondering how to go about removing it. The paint should be cleaned up as soon as it is spilled, while it is still wet. If so, you'll be pleased to know that removing it from carpet can be easy.
Step 1 - Sponge the Stain with Cold Water
Using a sponge to gently blot away as much latex paint as possible. A washcloth can be used in place of a sponge if it is highly absorbent. After you've gotten rid of as much paint as possible with the preliminary blotting, soak the sponge in cold water and proceed with another round of meticulous blotting. Once you think you've removed as much paint as this step allows, move on to step 2.
Step 2 – Use soap or Paint Remover
Now combine 1 cup of lukewarm water with a teaspoon of dishwashing detergent. Mild detergents work best for this process. Soak your sponge in this mixture and vigorously blot the stained area. Continue to blot until the latex paint has been completely removed. This washing should help, but there are also chemical products sold that are made specifically for removing latex paint. Follow the directions on the bottle. Wear goggles or safety glasses with side shields, especially when using a chemical remover.
Step 3 – Soak the Stain
If the spill is more than a few inches wide and the paint is still wet, pour large quantities of water on the stain and pick it up with a wet/dry shop vac. Several gallons of fresh water will dilute and combine with the paint until the paint is gone, sucked into the vacuum with the water.
Edward Kimble, professional painter and author of Interior House Painting Blog, contributed to this article.
