Login Error
Close
How to Get Reverse Osmosis Water Purification in Your Home
by DoItYourself Staff
what you'll need
  • Reverse osmosis water purification system
  • 1/2 inch drill bit
  • Smaller drill bit
  • Teflon tape
One of the most known water purifier systems at present is the reverse osmosis water purification system. This water purification technology is an economical way of removing contaminants which promises a success rate of 90 to 99%. If you are dealing with water containing perchlorate and nitrate then reverse osmosis water purification is the best water purifier system for you. The structure of membranes utilized in this water purification technology is designed to fight against various sizes of organics and bacteria. The good thing about reverse osmosis water purification is that it filters out good chemical such as calcium so there’s no worry that you maybe losing good chemicals in your water. The contaminants found in the water are flush backed to the water supply of the community. In addition, it is a water purification system that does not require complicated maintenance. It can be maintained easily for the reason that it has its own ability to clean its system while water purification takes place.
Step 1 - Importance of Water Purification
It is a fact that community water supply is not safe all the time. Therefore, it is vital to use water filtration system to have clean and safe water in your home. It helps in preventing sickness and harm that maybe caused by drinking unsafe water. Also, through water filtration technology such as reverse osmosis water purification, you are preventing yourself from drinking harmful water substance everyday. In fact, the Center for Disease Control (CDC) cited reverse osmosis as the best water purification method.
Step 2 - Get the Materials Ready
Buy reverse osmosis water purification system. Read and understand the installation manual to familiarize yourself with the procedures.
Step 3 - Select a Location
Select a location for the reverse osmosis water purification faucet. Drill a hole to place your reverse osmosis water purification faucet. After that, install the reverse osmosis water purification faucet system and tighten it up.
Turn off the valve for the cold water supply then attach saddle valve to it. Drill a hole into the drain pipe then fasten the waster water line. After that, insert the valve above the hole.
Step 4 - Check the Manual
Check the instruction manual to see if elbow fittings or tee should be assembled to the tank and system filters. Select a location below the sink to place the storage tank and bank of filters then attach the lines.
Step 5 - Check the Tank
Turn the cold water supply, half way. Close the reverse osmosis water purification faucet once the filters are filled with water. Then check the first tank for impurities. If there are, flush it.
Installing reverse osmosis water purification is not complicated. The advantage of installing it yourself is that you can save about 75% as compared to hiring a professional installer.
 forum activity
