Login Error
Close
How to Get Rid of Moisture between Window Panes
by DoItYourself Staff
If window moisture has long been a problem in your home, you're probably wracking your brain trying to figure out how to get rid of it. Well, don't fret, because ridding your home's windows of moisture is a very simple task that can be completed with the aid of a few readily available tools. Read on to learn everything you'll need to know about making window moisture a thing of the past.
Try Using a Fan
One of the easiest ways to get rid of window moisture is to simply fan it out. Begin this step by placing a common household fan in front of your moisture-stricken windows. You'll now want to adjust the fan's speed to reflect the difference between the indoor and outdoor temperatures, as moisture is generally caused by a considerable difference in temperature between your home's interior and exterior. For example, if there is a significant temperature difference, set the fan at its highest speed. You'll know if the fan has been set on the wrong speed if additional layers of window moisture begin to form.
Seal Any Window Cracks
Window cracks are another common cause of window moisture, so if fanning proves unsuccessful, thoroughly check your windows for cracks. Most smaller cracks can be patched with the aid of specialized sealant, but if the cracks are noticeably large, you will most likely need to replace your window.
So there you have it. Utilizing these two tried and true methods of moisture removal, your home's windows will be nice and clear in no time.
 forum activity
