How to Glue a Tubular Tire
When the time comes to glue a tubular tire you’ll need a few things, including wax thread, rubber cement and some latex solution. Tubular tires are glued to the rim of the wheel and have an inner tube permanently affixed to the tire casing.
Getting the Inner Tube Out
Remove the tire from the rim and peel back the tape inside the tire. Trim some of the stitching in the tire and then take out the inner tube.
Clean and Dry the Inner Tube
Hot water and detergent should be sufficient to use to wash your inner tube. Dry it well, as water will interfere in the bonding process when gluing the patch to the tube.
Patching Kits
Some patching kits contain thread, patches, glue and instructions on repairing tires. These kits are economical and easy to find.
Gluing Tape
Gluing tape replaces a rubber patch and is a fast and efficient way to repair a tubular tire. Gluing tape is recommended for emergency repairs.
Patching the Inner Tube
If using rubber cement, place a little over the area to be patched and do the same with the patch piece. Press down on the patch firmly to adhere. With gluing tape, it is not necessary to use glue unless the puncture is large. Just position the patch and smooth it down.
Stitching the Tire
It is easier to follow the previous stitches than to create your own. Stitch evenly and firmly and secure tightly when finished.
Latex Solution
Latex solution is used to glue the base tape, stitching and inner tube. Spread evenly and generously over the inside of the tire, stitching and base tape before returning the inner tube. Place the inner tube into the casing and glue the base tape over the top of the tire.
Gluing the Tire to the Rim
Use rubber cement to glue the tire back onto the rim.
