Login Error
Close
How to Glue Extensions in Short Hair
by DoItYourself Staff
 Glue extensions are a temporary method for adding instant volume and length to short hair. Many women have followed the lead of celebrities by using hair extensions to change their look.
What are Glue Extensions?
Hair extensions come in sections of synthetic or human hair. The extension is sewn to together at the top and can be found in various lengths. Choose the hair extension that matches your hair color. Human hair extensions can be dyed, curled and styled, while synthetic types can’t be colored or withstand the heat from flat irons and hair dryers.
Glue Extensions for Short Hair
To use glue extensions in short hair, it should be thick enough to cover the bonded areas. Also, the short hair must be able to support the weight of the glue extensions. Hair extensions for short hair can camouflage hair loss. Fill in bald spots with short extensions to make your hair style fuller.
Glue Extension Products
You need to purchase a bonding glue for applying hair extensions. A glue remover is necessary to take out hair extensions easily and without damaging existing hair. The glue remover breaks down the glue so the hair extensions are taken out without tugging or pulling. These products are available in hair salons and online.
How to Attach Glue Extensions
Using a fine tooth comb horizontally part your hair where you want to begin attaching the hair extension. Clip natural hair out of the way. Apply glue to the hair extension and place it on your hair as close to the part as possible without putting it on your scalp. Set glue with a hair dryer. Do not glue a hair extension to your scalp. You may need a friend to help you to continue applying hair extensions around your head. Comb your hair over the glue extensions. Depending on how thick you want your hair you can continue the process with another part.
How Long do Glue Extensions Last?
When you glue extensions, they can last two to three weeks with proper care. Usually women glue extensions into their hair for special occasions like parties and weddings, so they only want them to stay in for short periods of time.
Caring for Glue Extensions
Glue extensions will stay in through washing if you use a gentle shampoo and conditioner. Be careful when washing glue extensions; don’t rub the shampoo and conditioner directly on the area where they are attached to your hair. Conditioner should be used regularly on your extensions, since they have a tendency to become dry and frizzy. Avoid extended exposure to chlorine, and wash your hair immediately if you swim in a chlorinated pool. It is best to sleep with your hair completely dry and kept in a ponytail or braid.
Are Glue Extensions Healthy for Your Hair?
Glue extensions can cause damage. The glue can burn and dry out your hair. Heavy extensions pull on your scalp resulting in thinning hair. It is difficult to clean your scalp with glue extensions in it creating unhealthy hair. Sometimes hair extensions can cause headaches or allergic reactions to the glue.
 forum activity
