Login Error
Close
How to Hang a Glass Bathroom Shelf
by DoItYourself Staff
what you'll need
  • Level
  • Pencil
  • Power drill
  • Glass shelving kit
  • Screwdriver
  • Hammer
 Adding a glass bathroom shelf is very useful to the bathroom. It does not need much maintenance. Cleaning is easy and it is impervious to water or moisture. It can make your bathroom look better. The good looking bathroom is important to start a day actively. If you decided to hang a glass bathroom shelf in your bathroom, get one from any home improvement store. The installing process of the glass bathroom shelf is really simple and it will take only an hour or less to install. Glass bathroom shelves need to be handled with care. They are easily breakable; so you have to be very careful while installing it on your bathroom wall.
Step 1 – Select a Place to Hang Glass Bathroom Shelf
Decide where to place it in your bathroom. Then, take a pencil and a level to draw the model onto the wall. Draw the shape of the shelf on the wall lightly using a pencil. Place the level horizontally to the wall, then wait until the bubbles disappear. By doing so, you can make sure that the shelf will be hanged straight.
Step 2 – Drill the Wall
Once you have finished the sample drawing, take the bracket and hold on the wall. You will see the holes to place screws on the bracket. Take pencil and mark those holes. Now you will know where you have to drill on the walls. Use power drill carefully to drill holes on the wall. After drilling the holes, insert the fastener inside. If you press it by hand, it is enough. However, you can use a hammer to tap it inside. Remember that the fastener should fill the hole. Next, place the screws in it.
Step 3 – Place the Screws
The screws needed to hang the glass bathroom shelf will be given in the package of shelf itself. Take the screws and see which one is coming where in the bracket. Then, place the screws on the fasteners you have tapped in the holes using screwdriver, hammer or drill.
Step 4 – Hang the Glass Bathroom Shelf
Check the screws to make sure that they are strong enough to carry it. You do not want the glass bathroom shelf to gall to the ground and shatter to pieces because of the loosened screws. When you are hanging it, make sure that every screw is inserted in the holes of the bracket. Lift the glass bathroom shelf carefully and place it on walls using the screws and holes in the bracket.
 forum activity
