Login Error
Close
How to Hide Electronics Cables
by DoItYourself Staff
what you'll need
  • Zip ties
  • Cable management system
Organize and hide your electronics cables to keep your home looking good and avoid electrical problems. Knowing how to hide electronics cables will keep them out of the way so that people won't trip on them or even see them.
Step 1 – Combine Wires
In order to keep your wires from becoming tangled and confusing, use zip ties to attach wires to each other. This will pull all the wires into one tightly connected unit. You will be able to run the wires directly behind the  electronics which are using the wires  and manage any wires from becoming loose later.
Step 2 – Install a Cable Management System
The cable management system is little more than a cover for your cables. The boxy cover attaches directly to your wall with the included hardware. Simply place the bundled wires withing the management system and attach to the wall.
Step 3 – Move Your Electronics
Often the best way to get rid of cable clutter is to move your electronics closer to the things they are being plugged into. This includes speakers and electrical outlets.
 forum activity
