Login Error
Close
How to Hook an Antenna to a Coaxial Cable
by DoItYourself Staff
what you'll need
  • TV coaxial grounding block
  • RF coaxial cable
  • Power drill
  • Screwdriver
  • TV set
  • Digital converter
A coaxial cable transmits the audio/video signal from your antenna to a TV or a connector box. Some antennas come with a coaxial cable, but if you have a large antenna mounted on your home’s roof, it might use ribbon cables instead of a coaxial cable. Follow the 11 steps below to attach your antenna to a coaxial cable. If your antenna supports the coaxial cable, jump to step 8 directly.
Step 1 – Buy the Grounding Block
In case your antenna uses ribbon cables, you will need to buy a device that links the ribbon cables with the RF coaxial cable.
Step 2 – Ground the Device
To protect your home, you should ground the device you bought in Step 1. Place a metal rod in the ground outside your home and screw the block into it. You will need to drill holes for this.
Step 3 – Connect the Ribbon Cables
Connect the ribbon cables coming from the antenna to the grounded block. Place the U-shaped tip of each cable under the base of the corresponding screw-down terminal. Screw down the terminal to secure the cables.
Step 4 – Connect the Coaxial Cable
Connect the RF coaxial cable to the block. Generally there is more than one coaxial port. You can connect to any of the ports.
Step 5 – Connect the Cable to Your TV
Route the coaxial cable to your television. For this, you might need to drill a hole into a wall of your home to pass the cable through. At the back of your television set, you should find a coaxial port. Connect the coaxial cable to your TV through this port.
Step 6 – Connect the Converter
If you use an analog antenna, you will also need a digital converter. Connect the cable to the digital converter box’s coaxial input port. Then connect the box to your television with another coaxial cable.
Step 7 – Connect the Female End
If your antenna supports coaxial cable, take a male to female coaxial cable and attach its female end to the coaxial port on the antenna.
Step 8 – Untangle the Cable
Run the cable to the television or the converter box, as the case may be. Make sure that the cable is untangled; otherwise you will lose picture quality.
Step 9 – Connect the Male End
You need to connect the male end of the coaxial cable. The cable goes into the “In” port of the television or the box.
Step 10 – Connect the Converter
If you are using the converter box, you will need to take a male-to-male cable and connect it to the “Out” port of the converter and the “In” port of your television.
Step 11 – Turn on the Television
Turn on the television as well as the antenna if you use a power antenna. If signal quality is poor, check and tighten the cable connections.
 forum activity
