Login Error
Close
How to Inflate an Inflatable Boat
by DoItYourself Staff
Inflatable boats are great recreational vehicles and they are also a life saving device if you are ever in trouble. Learning how to inflate an inflatable boat quickly and easily could possibly help to save your life. There are a few different options for inflating an inflatable boat quickly. The easiest option would be to inflate the boat by blowing into the valve with your mouth. This is possible with smaller boats, however if it's very big then you're going to struggle. Also this requires quite a long time to complete. Here are a few other methods:
Using Equipment
If you don't like the idea of blowing the boat up with your mouth then another option would be to use some form of equipment to inflate the boat. To do this you can either use a compressor or some form of other inflation device. Air compressors will require power and so these are only suitable if you have power available.
An air compressor should be able to fully inflate a boat very quickly without you actually needing to blow it up yourself.
Checking the Air Pressure
You should also check the air pressure in each part of the boat to make sure that it's working properly and that there are no leaks. Then make sure that all of the valves are sealed correctly.
 forum activity
