Login Error
Close
How to Install a Corner Bathroom Sink
by DoItYourself Staff
what you'll need
  • Measuring tape
  • 2x 10 inch wood block
  • Piece of water-resistant drywall
  • Pipe wrench
  • Pencil
  • Screws
  • Drill
  • Level
A corner bathroom sink was designed to be installed in a corner that has been created by two adjoining walls. It is different in design from a sink that is intended to be mounted in the middle of a room or wall. A number of reasons could be taken when choosing a corner sink such as aesthetic value, space limitations, plumbing limitations and issues on work flow.  Some designs also come with a counter top that is built into it. This provides additional utility space for the bathroom. A number of different styles, colors and materials can be considered and you do not need to have any special skills to install one. Except for getting the help of someone to hold the sink while you are attaching it to the wall, you can finish the whole project by yourself.
Step 1 - Measuring the Area
Measure the sink height that you prefer from the bathroom floor. This can range from 30 to 38 inches. Mark your measurement on the walls and locate the studs. Measure 16 x 16 inches on a wallboard and cut it out with a saw. You should then install a block of wood that measures 2 x 10 inches between the studs. Toenail screws into the studs to do this and ensure that your wood block is flush with the front borders of the studs.
Step 2 - Making the Plumbing Holes
Cut out for pipes that are for the drain line and water supply lines.  Put the mounting plate on the wall where you are going to install the sink and mark the holes with a drill.
Step 3 - Installing the Sink Fixtures
The next step would be to install the drain, pop up and faucet assemblies on the bathroom sink. Be sure to follow what the manufacturer recommends to have a proper installation. Attach the mounting plate on the block that you have installed earlier and make sure that it is level before securing it fully.
Step 4 - Attaching the Corner Sink
Place the bathroom sink on the mounting bracket and secure it with anchor bolts. The trap should be connected with the drain stub that is on the wall while the shut off valves should be connected to the supply pipes for water. If there is a trim piece that comes with your bathroom sink, you will have to install it during this step.
Step 5 - Checking Your Work
To make sure that you have done a proper installation, turn the shut off valves on. Check for leaks on the fittings. If you find some, you will have to tighten the fittings to stop them.  If there are legs that were intended for installation under the front part of the bathroom sink is included in the package, this is the time to install them. Make sure that you follow the steps that were recommended by the manufacturer to ensure proper installation. Check if you need to make any further adjustments on the other sink fixtures such as the faucet or pop up fixtures. If no problem is detected, you can now enjoy your new bathroom corner sink.
 forum activity
