How to Install a Crown Molding Shelf
what you'll need
- Crown Molding (for the shelf)
- 1x4 inch thick piece of wood (for the mounting plate)
- Glue
- Nails
- Measuring Tape
- Scale
- Hammer/ Nail Gun
- Saw
- Caulking Material
- Sandpaper
A crown molding shelf is an inexpensive way of adding a new dimension and aesthetics to your wall. It can be easily made using crown molding; you can mix and match if two adjoining rooms have different crown moldings to aesthetically link them together by adding crown molding shelves. Installing a crown molding shelf is easy all you need is a mounting plate to place it on. Never try to hang heavy objects directly to your dry wall, it will rip the paper and will require patching.
Step 1 – Assembling Your Crown Molding Shelf
Assemble your crown molding shelf, which you can make yourself at home using left over crown molding pieces, glue, miter box and a saw, it’s a relatively simple task. Prepare, prime, paint and finish it before installation.
Step 2 – Cutting the Mounting Plate
The shelf will be hung to a wall by placing it on a board. You can cut out a one by four inch thick piece of wood nearly the same length as your shelf, leaving spaces at the edges. Use a measuring tape to mark the measurements of the shelf onto the wooden piece and than using a saw cut it to length.
Step 3 – Installing the Mounting Plate
Securing your board to the wall will serve as a resting unit or a mounting plate for the shelf onto which you can place your shelf. You cannot directly nail the shelf into the wall as your dry wall won’t be able to sustain the weight and will be damaged. The board itself will be nailed into framing studs to ensure a strong hold and so, that your dry wall is not damaged.
Step 4 – Installing the Crown Molding Shelf
To install the shelf onto your mounting plate place the shelf over the length of the plate in such a way that the crown molding shelf is perfectly resting on top of it. Using a nail gun or regular nails (if you don’t have a nail gun) secure the crown molding shelf into place on the wooden plate. Now the crown molding shelf has been installed onto your wall and the remaining touch up job can be done. If you want to add a back plate on top of your crown molding shelf, you can saw a piece of wooden plate the length of the crown molding shelf and add to the top of shelf. Prime and paint in accordance with the shelf before installation.
Step 5 – Sealing the Edges
Seal the edges around the crown molding shelf using caulking material. For the best effect make sure it is the color of the shelf. Once it has dried out, sand it using sand paper and touch up with paint if needed. Caulking the edges will give a tight seal around crown molding shelf, ensuring it stays in place, plus it gives a more finished look.
