How to Install a Garage Door Gasket
what you'll need
- Garage door gasket kit
- Measuring tape
- Marker
- Sponge
- Utility Knife
- Water
The garage door gasket prevents dirt and sand from entering the garage. It also acts as an insulation from the weather. Installing a garage door gasket is an extremely simple procedure. Read on to find out more.
Step 1—Measuring the Garage Door
The first step in installing the garage door gasket is to ascertain the measurement. Use a measuring tape to measure the width of the garage door. Take this as reference while buying the garage door gasket
Step 2—Buying the Garage Door Gasket
Head to the hardware store and buy an appropriate garage door gasket kit. The kit works best on untreated surfaces. Make sure to cross check with the representative if you are picking the right kit.
Step 3—Pointers while Buying
While buying the garage door gasket kit check the material, the size, the color and the adhesive composition. The length of the garage door gasket should be equal to or more than the width of your garage door.
Step 4—Getting Ready
Before you start with installing the garage door gasket make sure to have your work gloves on. In case you are allergic to adhesive fumes make sure to cover your nose and mouth.
Step 5—Prep Work
Clean the area where the garage door gasket is going to be installed. Rid the surface of any debris, sand or dust.
Step 6—Determining the Right Measurement
Now determine the accurate length of the garage door gasket. Place the garage door gasket on the door's bottom tack. With the utility knife cut off the excess garage door gasket.
Step 7—Testing the Position
The next step is to check if the garage door gasket is seated in the right position. Test this by closing the garage door. While closing the door, observe the rolling motion. If the door rolls on the flat surface of the gasket, you can be sure it has been placed properly. Also, at this point the humped surface will be inside the garage.
Step 8—Marking
The next step is to mark the area where the adhesive has to be applied. With a marker outline the inner and outer part of the garage door gasket.
Step 9—Applying the Adhesive
After marking the outline take the garage door gasket out of the track. Now apply the adhesive inside the outline. Do not apply excess adhesive as it will lead to clumping.
Step 10—Placing the Garage Door Gasket
Place the garage door gasket on the track. Apply an even pressure so that the whole of the garage door gasket sits accurately into the track.
Step 11—Wiping the Excess
The excess adhesive that oozes out of the track has to be cleaned. Use a wet sponge to wipe away the excess.
Step 12—Final Step
Close the door as the resulting weight will hold the garage door gasket in place. Let it set for 48 hours. That's all you need to do to install a garage door gasket.
