Login Error
Close
How to Install a Gas Pool Heater
by DoItYourself Staff
what you'll need
  • PVC pipe
  • Measuring tape
  • Plumbing compound
  • Hacksaw
  • Soapy water
  • Spray bottle
Pool owners who want to extend the swimming season even after the onset of winter should install a gas pool heater. These increase the temperature of the water in the pool, thus making it possible to swim in the colder months of the year.
Water passes into the heater through the filter and is warmed in its combustion chamber. It is then passed back into the pool, allowing you to swim in comfortably warm water.
Follow these steps to install one in your pool.
Step 1 – Purchase Your Gas Heater
Gas pool heaters come in a variety of sizes that determine their cost. Purchase one according to the size of your pool.
Step 2 – Select a Location for the Heater
When selecting an appropriate location for your heater, keep in mind the clearance distances above the unit and to its sides, to enable it to operate safely. These distances however will depend on the size and model of your heater and will be mentioned in the manufacturers instructions. You should also keep it as close to the filter as possible to avoid extra piping. Aim at installing it two to five feet from the filter.
Step 3 – Channel Water into Heater
Turn the filter off prior to installation. Begin plumbing the heater by measuring the distance from the return valve of the filter to the inlet valve of the heater. Cut and attach the PVC pipe there. This will help channel the filtered water into the heater.
Step 4 – Pass Warm Water into the Pool
Measure and cut another piece of PVC pipe and run it from the outlet valve of the heater to the water inlet of the swimming pool. This will take warm water into the pool. Use a plumbing compound to tightly secure the pipes and joints.
Step 5 – Connect the Gas Supply Line and Electrical Power
Make sure you check with your regulatory authorities before you hook up the gas lines. Some locations send professionals to install gas connections. Install a shut-off valve at the end of your gas pipe and run a flex gas line from there to the heater inlet.
Connect the 120-volt plug of your heater to an electric outlet. Install a covering over your outlet to protect it from the weather and plug the heater in.
Step 6 – Test the Setup
After your installation and setup is complete, you should test the unit to make necessary amendments. Turn the pool filter back on. Then turn the heater on and raise the temperature on the thermostat slightly. A fan will blow before the heater ignites. Check that the heater has a blue flame.
The temperature in the pool will rise shortly after you turn the heater on. Most heaters have flow sensors that detect water pressure and disable it from turning on if the water drops to a certain level.
Keep the power off when the pool is not in use to avoid accidents.
 forum activity
