How to Install a Hinge Pin Door Closer How to Install a Hinge Pin Door Closer
Screwdriver or electric drill with screwdriver bit
A hinge pin door closer will close an interior door you don't wish to close, yourself. For you to close a door automatically, using this closer, you will no long need to use the older, unattractive standard door closer. The hinge pin closer works efficiently without being obvious. Here's how to install one:
Step 1 – Remove the Old Hinge
Decide with hinge, bottom, middle, or top, you'll want your hinge pin door closer attached to. Then, use a screwdriver or electric drill to unscrew the screws from the old hinge.
Step 2 – Attach the New Closer
The new hinge pin closer plate and its screw holes should fit in the position of the hinge you removed. Use your screwdriver to attach the new hinge.
Step 3 – Insert the New Stop Pin
Locate a hole in top of your new closer that is closest to the door. Into this hole insert the adjustment bar that came with the closer. Do this also at the hinge pin bottom.
Step 4 – Test the New Closer
Once the closer is installed test it by allowing it to close the door. You can then adjust it to close the door more softly or harder.
