How to Install a Hollow Door
what you'll need
- Safety glasses
- Screws
- Hammer
- Measuring tape
- Plane
- Sandpaper
- Panel saw
- Drill kit
- Narrow and medium chisels
- Narrow strips of wood for doorstop
- Carpenters pencil
- Wooden wedge or doorstop
- Screwdriver set
- Measuring tape
Hollow doors are seen in modern homes everywhere due to their easy installation, low cost and basic efficiency.
When installing a hollow door, there are a few steps you need to follow in order to be sure the end result is even, stable and professional looking.
Step 1--Find the Lock Block
A lock block is a solid piece of wood that is pre-built into hollow core doors so that you have a solid section of wood to drill your lock into. This section will either be built in on the side or will run from the top to the bottom of your door. There should be a marking on the top, bottom or side indicating where the block is located. If located on the side--use a carpenter's pencil to mark off the lock block position on the face of the door as you will probably cut off the factory markings when sizing the door.
Step 2--Take Careful Measurements
Most hollow doors are installed in pre-existing wooden frames. This requires careful measurement to ensure the door will open and close properly within the existing frame. First, measure the width of the open space in the frame where the door will be hung. Take three measurements and average them in order to be sure the measurements are exact. Plane the door to width, trimming an additional 1/16 inch from the sides and the top of the door to allow for clearance. For the bottom, the recommended clearance is approximately 1/4 inch, but if you have carpet flooring, you may want to adjust this to suit your flooring.
Step 3--Sand Edges
Sand all trimmed edges smooth for a clean finish and smoother hanging process.
Step 4--Place Door
Set wedges at the bottom of the frame to hold up the door as you place it evenly into the frame. Check to see how it fits. If the clearance appears to be suitable, move on to Step 5. If not, trim door as necessary.
Step 5--Mark Hinges
Hinges placed on the right cause a door to open into a room, while hinges placed on the left cause a door to swing outwards. On whichever side you decide to use, draw a line 6 inches from the top of the door and six inches from the bottom of the door to mark off the hinge positions. Line up the hinge with each mark, and mark around the outline to accommodate each hinge.
Step 6--Chisel Hinge Recesses
With a sharpened chisel, make a series of cuts around the hinge outline. Chisel out a shallow recess according to the depth of the hinge flap itself and scrape out remaining wood. Test the fit, making sure the hinge lies level with the door itself.
Step 7--Drill Pilot Holes
Position hinge flaps in chiseled out recesses and mark the positions of the screws. Remove the hinge flaps and begin to drill pilot holes into the door in the positions that were marked.
Step 8--Screw Hinges to Door
Line up hinges and screw each hinge into the door. Secure wedges under door and have someone hold the door against the frame in the open position, with the hinge flaps laying open on the frame. Make sure the hinge knuckles are lined up with the frame and mark position of hinge using carpenter's pencil.
Step 9--Chisel Frame Recesses
Carefully chisel out a shallow recess into the frame as you previously did with the door. Test the fit, making sure the hinges are positioned correctly and trim door if necessary.
Step 10--Screw Hinges to Frame
Reposition door so that the hinge flaps are lying neatly in the recesses and mark out screw positions. Drill the pilot holes into the frame and screw the hinges into the door.
Step 11: Build a Door Stop
A door stop is a narrow strip of wood built into the frame that stops the door fom swinging all the way through when opening or closing.
Step 12: Measure the Frame
With the door closed, mark around the frame in the position you are installing your door stop. Measure the markings on the frame and cut three narrow strips of wood according to these measurements.
Step 13: Screw in Door Stop
Secure doorstop to frame using at least three screws on each side. Test it out, making sure your door opens and closes properly.
