Login Error
Close
How to Install a Home Automation Thermostat in Your Home
by DoItYourself Staff
what you'll need
  • Home Automation Controls
  • Thermostat
  • Screwdriver
Home automation thermostats are becoming extremely popular because they make it possible to control things automatically, even if you're no where near your home. If you are interested in home automation then you might want to learn about how you can automate your thermostat.
The thermostat is a very clever temperature controlled switch which will control when the boiler fires to produce hot water for the heating. An automatic thermostat can be used to control exactly when the heating turns on and off. Home automation controls don't just make your life simpler, but they will also look after the environment.
These home automation controls are a great way to accurately control when the heating fires up and when it shuts down. Automated thermostats will mean that you don't need to burn as much gas to heat your room.
Step 1 - Safety
As you will be working with the electrical systems in your home it's important to first switch the power off. You can either remove the circuit breaker from the individual circuit or you can shut the complete power off by using your homes master power supply switch.
Step 2 - Removing the Old Thermostat
Unscrew the old thermostat from the wall and set it aside. Once the old thermostat is removed you will then be able to replace it with a new home automation thermostat system.
Step 3 - Fitting the New Thermostat
Unpack the new home automation thermostat and read the instructions. This will need to be wired into the homes boiler which will make it possible to control the boiler temperature automatically.
Thermostats will be fitted differently depending on the brand and type of thermostat being fitted.
Step 4 - Setting up X10 Automation Modules
Home automation is made out of X10 automation modules. X10 automation modules come in many different shapes and forms. They are used to control the different modules over the existing power lines in your home. Your X10 thermostat will be able to communicate with all of these different X10 modules.
Step 5 - Installing Remote Controls
X10 remote controls and transceivers can be used to control your X10 home automation thermostat control. These remote controls are powered by batteries and communicate with the other home automation systems using a module which is plugged into your homes electrical outlet.
Step 6 - Timers
Timers can be set up using computer software or other X10 modules. These can be installed easily and computer software can be purchased on the Internet. This will make using the home automation thermostat much easier and simpler.
 forum activity
