How to Install a Molding Chair Rail Around a Curved Wall
For years, home owners have looked to wood molding chair rail to protect walls from wearing and scratching caused by chair backs pushed up against these walls. But as home design and interior wall design trends change, so do wall surfaces change to favor wall curves. Many of these homeowners have chosen to abandon the use of inflexible wood chair rails. But with the introduction of the more flexible paneled chair rails, homeowners can now protect interior walls and at the same time use more decorative chair rails. To install these flexible and decorative paneled chair moldings for protective or decorative use, refer to the information below.
Things you'll need:
- Measuring tape
- Chalk line
- Soapy water
- Sponge
- Fine tooth saw
- Miter saw
- Putty knife
- Caulk adhesive
- Finish Nails (No. 6 or No. 8)
- Hammer
Step 1 – Choosing Your Chair Railings
Many of these panel chair molding designs, available in sizes from 24 inches high to 48 inches high, resemble plaster castings with patterns that can please the eye and at the same time create new decorative wainscot appearance. All of these panel moldings, although many present an authentic plaster or wood appearance, are constructed of durable plastic that will protect your walls from scuffing by chair backs. Most panels come primed for painting.
Step 2 – Positioning Your Chair Rail
Before attaching your chair rail, choose the height you'd like it to be. If you're looking for it to be more functional, measure up from the floor to the top edge of your chair backs. This is the height your chair rail should be. If, on the other hand, your objective in installing the chair rail is mostly decorative, position the railing where it will give you the look you want.
Step 3 – Preparing Your Wall
Your wall will need to be clean and free from bumps and other debris that will prevent the panel from lying flat on the wall. Use a putty knife or joint knife to smooth your wall surface, Also, use a sponge and soapy water to remove soil or greasy spots. Flip a chalk line on your walls to mark the line where you will attach the rail top edge.
Step 4 – Cutting Your Molding Pieces
You will need to cut and fit molding pieces that connect. Since most of these panels come with patterns, you'll need to be careful in cutting your pieces so the patterns are continuous from one piece to another. Lay out the strips end-to-end beneath the place on the wall where they will be attached. Cut all pieces before attaching them to the wall.
Step 5 – Applying Adhesive
Use your putty knife to apply and spread adhesive to your first molding strip. Attach the strip to the wall, using finish nails. Leave the nail head exposed to allow you to pull it from the strip when the adhesive is set. Use this same procedure to attach all the molding strips. Then, allow the adhesive to dry.
Step 6 – Finishing
When your adhesive is dry, remove the nails and fill the holes the nails have left with caulk or putty.
