How to Install a Motorcycle Muffler
what you'll need
- Muffler specific to your motorcycle
- Set of various sizes of wrenches
- Matching socket sets
- Rust-busting lubricant
- Grease or anti-seize
- Wooden block and hammer
All motorcycles have exhaust pipes to let the combustion exhaust out and motorcycle mufflers on them to keep the noise down. Most of the modern motorcycles have an exhaust pipe made of two parts, namely the header pipe and the muffler. The muffler can either be of welded or removable type. If the exhaust noise is too loud (or not loud enough), remove the old/damaged muffler and replace it with a new one.
Step by Step Procedure
- Step 1 – Choose a Muffler
The muffler has to be selected by taking in to considerations many factors like length and diameter of the header pipe, length of the intake track, carburetor size and cam timing and lift. After analyzing all these factors, buy a muffler that matches the specifications of your motorcycle. Only correct mufflers will help to reduce/increase the noise level of exhausts. Remember the old motorcycling adage: Loud pipes save lives. (Just be aware of local noise ordinances and/or vehicle code.)
- Step 2 – Check Materials
Before you start to remove the old muffler from the head pipe, find out the availability of all required tools and their matching fasteners of the exhaust pipe of your motorcycle. You must also find out whether the radiator has to be removed or not (it depends on the model of your motorcycle).
- Step 3 – Remove the Old Muffler
Using the wrenches and sockets, loosen all the bolts and fasteners and keep them aside. Pull the muffler backwards; however, it may not budge immediately. If it is hot or rusted, you might have to spray little amount of rust-busting lubricant. Leave it for some time and then try again. Still if it does not budge, try to give blows on it with a wooden block hammer or a rubber mallet.
- Step 4 – Remove the Head Pipe
Next, remove the head pipe unit. It may be more time consuming than the removal of the muffler. Again you may need to apply rust-busting lubricant and blows to remove the head pipe.
- Step 5 – Fix the New Unit
Check and remove the old gaskets. Use grease and place the new gaskets in place. Place the head pipe by tightening the bolts of the retaining collar. Apply grease at the other end of the head pipe and insert or slip the muffler into it. Loosely screw them together and check if everything is fine and fits snugly. Do not use force to slip the muffler into the head pipe or to fit them together. In case of improper fit, you may have to do a bit of trimming or filing for a nice fit.
- Step 6 – Finishing Touches
Tighten the bolts and screws, but do not apply more pressure as the head gasket might get damaged. Start your motorcycle and check the exhaust from it. You will notice a change in the noise of exhaust due to change of muffler.
