How to Install a Natural Gas Range
what you'll need
- Anti-tip Bracket
- Screwdriver
- Soap and Water
- Hand Held Spray Bottle
Many people prefer cooking with a natural gas range as opposed to an electric model due to the even heat distribution and flexible temperature control. If you want to install a natural gas range in your kitchen, follow the step-by- step instructions below and you'll be cooking in no time.
Step 1 – Check for Gas Line
Before you buy or attempt to install a gas range, you need to make sure that there is a gas supply to the correct area of your kitchen. If you have previously used an electric range, you may need to install a gas line to the required area. Check with your local authorities to see if there are regulations that you need to conform to when installing the lines. A professional contractor is best employed for this particular task.
Step 2 – Install Anti-Tip Bracket
It is recommended that you install an anti-tip bracket to prevent the range from moving and pulling the gas pipe from the wall. Secure the bracket to the wall where the back left leg will sit when the range is position, making sure it is flush with the wall.
Step 3 – Remove Door
To make it a little easier to move the range, you should remove the oven door and kick plate before making the connections. The kick plate is normally secured with a screw that can easily be removed. Be careful when removing the door as the hinges are often spring loaded and can cause an injury if you get your finger trapped. If you open the door fully, rotate the hinge section that attaches to the internal bracket so you can lift it out of position easily. If you have problems removing the door, consult the instructions manual rather than forcing it.
Step 4 – Make Connections
Move the range closer to it's final position, then make the required electrical connections for the ignition system and clock. Turn the gas supply off before attaching the gas connector to the shut off valve. Next, connect them to the gas pipe fitting on the rear of the range. Tighten the connection securely but don't make it too tight. Never use any tape or putty to make this connection. If there is a problem and the connections don't fit, consult a professional installer for advice.
Step 5 – Check Gas Supply
Make sure that all of the control knobs on the range are in the “off” position then turn the gas supply back on. A safe and easy way to check that your connection is sealed and no gas leaks exist is to use a spray bottle of soapy water to cover all of the valves and connection points. If bubbles begin to form, it indicates that gas is escaping and you need to tighten the connection. Repeat this process until no soap bubbles form.
Step 6 – Finishing Touches
Move the range into it's final position and connect it to the anti-tip bracket. Adjust the legs so that the range is level with your counters and the top is not sitting at an angle then replace the kick plate. Position all of the burners, grates and the exhaust cover. Replace the door then open and close it a few times to make sure it works smoothly.
