How to Install a Paver Walkway on a Slope
what you'll need
- Pavers
- Crushed rock
- Compactor
- Landscape paint
- Sod cutter
- Landscape border
- Shovel
- Rake
A paver walkway is a great way add some character and definition to your landscape, garden, entrance area, or backyard path. There are plenty of different pavers that can be used to build long lasting walkways. Installing pavers is not a difficult project in technique. However, there is a lot of labor involved. There are times when you may need to install a paver walkway on a slope. While there is not much different in this installation, you will want to make sure the ground is level.
Step 1 - Determine Location for Paver Walkway
Before doing any work to the sloped area, you will want to determine where the actual walkway will be located. Use some landscape paint and mark the outline of the walkway. Try to choose the area with the least degree of slope.
Step 2 - Prepare the Ground
Once the ground has been marked with the paint you can prepare it for the pavers. Rent a sod cutter to make the project easier. Use the sod cutter to cut through the sod and leave it in lengths that you can roll up and transport to another area of your lawn. Once the sod is removed, make sure to remove any rocks, roots, or other obstacles. Rake the ground until it is smooth and even. This is important as any depressions, holes, or areas were water can pool up will weaken the foundation of your paver walkway.
Step 3 - Install a Border
Using a landscape border of your choice, begin installing it. A good border is a small plastic type that has a small curved reveal. This will help to not only define the space of the walkway, but also give you a reference point when edging your lawn. Set the border on the side of the area that has been cut out. Drive in stakes to hold them in place.
Step 4 - Spread Sand Over Ground
With the soil prepared for the pavers you will then need to spread out a layer of crushed rock. Spread the rock out on the ground to a depth of 2 inches. Smooth it with a rake and then run over it with a compactor. This will make a solid surface for the pavers.
Step 5 - Install Your Pavers
Starting at the bottom of the walkway, lay out your pavers. Start in the center of the walkway and work out to the sides. If you need to cut any of the pavers, then use a chisel to score the paver. Break it off with a hammer. Continue installing the pavers until the walkway is completed.
Step 6 - Spread Sand Over Pavers
To cement the pavers in place you will need to use some sand. Concrete sand will be a good option for working on a slope. Spread the sand over the top of the pavers. Sweep it into the cracks and crevices. Use the compactor again to make sure that it is all level and stable.
Step 7 - Wash Off Excess Dirt
Use a hose and run it over your walkway. This will remove any of the standing dirt that has been left on top of the pavers.
