How to Install a Pellet Stove Insert
what you'll need
- Pellet stove
- Brush
- Protective overalls
- Working gloves
It is advisable to buy easy-to-use pellet stove inserts, as they require minimal maintenance and are not hard to operate. These appliances are available in a wide range of designs, and they support either top or bottom fed stoves. They consume less fuel compared to other heating devices and they are designed to conserve energy, which makes them cost effective.
Step 1 – Locate Suitable Position
For the pellet stove to work effectively, it has to be placed at a convenient and suitable location in the house. A fireplace is an ideal place to install the appliance. A new position can also be established if the appliance is used as a secondary heating device.
Prepare the area by cleaning the floor and lining it with protective material, such as refractory cement. This might take a few days to dry. Do not install a pellet stove on normal surfaces.
Step 2 – Quality Pellet Stove
Buy an easy-to-use and high quality pellet stove, as they are better suited for home use. Take into consideration how power is supplied to the appliance. Choose between electrical and gas supply, depending on what is readily and cheaply available in the home. Other factors to consider include the size of the appliance. Keep in mind the amount of space to be used when selecting the device.
Step 3 – Prepare Fireplace
Clean the old fireplace and remove materials such as wood, soot, debris or creosote. Use a brush to sweep the chimney flue. Remove bird’s nests and pests’ dropping as well.
When installing on new surfaces in the home, make sure the setting prepared for the installation is dry.
Step 4 – Position Pellet Stove
Place the new pellet stove in the fireplace and make sure it is properly propped and adjusted to fit in the space. Position it so that it gets maximum aeration and that wastes such as smoke have direct access to the chimney.
To position the pellet stove on freshly made floor, confirm that it is well positioned. Do not place it near furniture, drapes, curtains or other items in the home. Make sure it is placed next to a power or gas supply. Check that the appliance has a direct supply of fresh air as well.
Step 5 – Configure Gas or Power Supply
Depending on the type of power supply required by the appliance, make sure it has easy access to such outlets. For an electric power supply, check that the plug has a direct outlet that is configured to match its voltage, ground and polarity. This is a safety precaution and allows the device to work effectively.
If the pellet stove requires a gas supply, make sure it has a direct connection and the switch is properly connected to the appliance.
Step 5 – Test Pellet Stove
Place fuel in the pellet stove, turn on the switch and check the condition of the new appliance.
Tips
- Make sure that there is proper ventilation in the room where pellet stove is to be installed.
