Login Error
Close
How to Install a Roof Cap
by DoItYourself Staff
what you'll need
  • 50 foot tape measure
  • Roof cap or shingles
  • Hammer
  • Roofing nails
  • Utility knife
  • Roofing cement
When it comes to finishing off a roof project, the roof cap is the most important. A roof cap is covers the ridge of a roof in order to deflect water down the sides instead of onto the roofing material. Roof caps are available in many different styles from individual shingles to pre-fabricated caps that run the length of the ridge line. Installing a roof cap is an easy process, but does require some attention to detail for eliminating water damage. Here are the steps to take to install a roof cap yourself.
Step 1 - Measure Roof for Materials
Walk along the ridge of your roof and measure it with the 50 foot tape. If you feel that the roof is going to be longer, use a 100 foot tape. This measurement will help to determine the number of shingles you will need, or the number of pre-fabricated roof caps.
Step 2 - Measure Both Sides of Ridge Line
Once you have the roof cap purchased you can begin the installation process. Measure both sides of the ridge line to 6 inches below the line. With the measurement marked, run a chalk line along the roof at this six inch mark and snap the line. Do this for both sides.
Step 3 - Place First Shingle for Roof Cap
If using individual shingles for the roof cap, then start at the outside edge of the roof and lay down the first shingle. Lay the shingle so that it lies on both sides of the roof down to the chalk line. It should also be overlapping the last row of shingles by 2 to 3 inches. Secure it to the roof with a roofing nail 2 inches below the ridge line and just above the tar line.
Step 4 - Place Second Shingle
The next shingle is laid over the first with the edge just covering the glue strip on the first. Nail it with the roofing nails in the same way that you did the first.
Step 5 - Continue Installing Roof Cap
Using the same process as with the first two shingles, complete installing the roof cap in order to complete the roof.
Step 6 - Install Pre-Fabricated Roof Cap
If you are using a long metal pre-fabricated roof cap you will need to use a different method. In some ways it is much easier. Start at one edge of the roof and lay the cap on the ridge line. Use foam insulation along the edge of the roof cap where it meets the metal roofing material. Remove the paper backing and stick it to the metal roof. Press the cap into the foam and drive in self sealing screws along the edge of the roof cap.
Step 7 - Install Second Length of Roof Cap
Once the first section is secure you can install the next section. Slide the second section under the first by 1 to 2 inches. Install the foam insulation piece in the same way and secure the cap with self sealing screws. Continue to install the roof cap in the same way until it is finished.
 forum activity
