Login Error
Close
How to Install a Satellite Dish on a Tile Roof
by DoItYourself Staff
what you'll need
  • Ladder
  • Signal meter
  • Adjustable wrench
  • Phillips screwdriver
  • Drill with 3/8 inch bit
  • Staple gun and staples
  • Universal tile roof mounting bracket
Installing a satellite dish on a tile roof has to be done with extra special attention. Your tile roof is weatherproof but not destruction proof when it comes to attempting to drill holes to install a satellite dish. Drilling a hole or removing a section of tile to mount your dish compromises the integrity of your roof and can cause leakage problems in your roof. Using an epoxy or other type bonding material can cause damage to your tile should you ever need to relocate your satellite dish.
With the proper tools and material, you can install a satellite dish on your tile roof without compromising the structure and beauty of your tile and obtain the same results you would on a shingled roof.
Step 1: Location
Determine the location on your roof where you want to install your satellite dish. The point you choose should be as level as possible near the edge of the roof or at the peak so that the dish itself will not be angled. Ensure that your dish points in the direction to receive the transmission signals from your satellite service provider.
Step 2: Install Mounting Bracket
Once you have determined the perfect location for your satellite dish, mount the bracket. Your bracket should have an aluminum base of at least 30 by 30 inches and a universal bolting pattern for the dish mount. The aluminum base will allow for flexibility of the base to conform to the shape and style of your tile and enable a tight secure fit. Once the base is installed with your tile, it will have a "built-in" appearance. Try to firmly move mounting bracket to check for stability.
Step 3: Attach Dish
Place the dish on the mounting bracket and secure it with bolts provided with your dish. Place the satellite's antenna arm in its proper location and attach the coaxial cable to the Low Noise Block and attach it the end of the arm.
Step 4: Adjust Dish Position
Now that the dish and arm are secure in place, you must adjust the direction and elevation of the dish in accordance to the instructions of your satellite service provider. Ensure that the tilt is of the dish is in line for maximum reception.
Step 5: Check Signal Strength
Take the signal meter and attach the coaxial cable to it. If the signal is weak, you will need to angle the dish to get the strongest signal your meter can read. Once signal is achieved, secure all bolts and screws to set final position.
Step 6: Run Cable to Receiver
The task now is to run the cable from the dish neatly to your receiver. Run the cable on the roof line and then alongside the wall to the closest point to your satellite dish receiver. Secure the cable to your roof line with the staple gun. If your home is a non-wood finish, you can use zip ties to secure the cable to the house exterior walls.
Step 7: Run Cable through Wall
With your drill and 3/8 inch bit, drill a hole through the wall and push coaxial cable through. Once the cable is inside, attach it to the back of your receiver. Connect receiver to your television and turn on both units. Set up your receiver per your service provider's instructions.
 forum activity
