Login Error
Close
How to Install a Vent in Sheet Metal Roofing
by DoItYourself Staff
what you'll need
  • Roof Vent
  • Tape measure
  • Marker or Chalk Line
  • Pencil and Notepad
  • Skill saw , Jig Saw or Reciprocating Saw
  • Screwdriver
  • Drill
  • Screws
  • Tar / Roofing Cement
  • Tar brush
  • Dust Mask
  • Hammer
  • Roofing Nails
  • Utility Knife
  • Shingles
Sheet metal roofing is a roof that is made out of metal; it is very durable and long lasting however it can get very hot inside the room during the summers. These roofs can withstand fire, snow, wind and other natural and unnatural calamities. It is light weight and also portable and cost effective. If given the right treatments like the anti-rust treatment, waterproofing treatment or even heat-reflective treatment can make the roof stay for a much longer time. By installing a vent on the roof, it helps in the circulation of air in the attic or roof space.
You will find different types of vents in the marketplace. You have to choose a vent with the proper ventilation system. A proper ventilation system has an intake vent as well as an exhaust vent. The intake vent lets in fresh air into the roof space while the exhaust vent allows air to escape from the roof space. Here is the right way to install a vent in sheet metal roofing:
Step 1: Decide the type of vent to install
Decide what type of vent will best suit the roof. This is important so that you can get the roof vent that you would like.
Step 2: Decide on the placement of the vent
See where you would like to place the vent based on the type of vent you would like to put on the roof. There are different types of vents that require different space and specifications.
Step 3: Measure the area where the vent is going to be placed
Measure the length and width with a tape on the marked area, note it down
Step 4: Mark the area
Using a chalk or marker, mark the area on the roof where the vent is going to be placed
Step 5: Draw an outline
Draw a rough outline of the vent by connecting all the marked points.
Step 5: Cut the roof
With the Skill saw, Jig Saw or Reciprocating Saw cut the roof using the outline as a guide until the hole is completely formed.
Step 6: apply a layer of tar
Use the tar brush and apply a layer of tar or roofing cement very carefully making sure that any rough edges are covered properly.
Step 7: Place the vent
Place the vent in position and drill holes with a drill and secure the vent with the use of roofing screws by tightening them with a screw driver.
Step 8: Fill any space
Apply another layer of tar for any open spaces after placing the vent and make sure that it is secured properly this time covering any open edges that are there to make sure that it is secured properly.
Step 9: Seal the underside of the attic
Apply a layer of tar on the underside of the attic to make sure that no spaces are left from inside, check to see if there are any open sot.
 forum activity
