How to Install an Exterior Light Fixture Box
what you'll need
- Fixture box
- Screwdriver
- Drill
- Drill bits
- Tape measure
- Hole drill
- Voltage meter
- Stud finder
- Chalk pencil
- Wire stripper
- Wire cutter
- Wire nuts
- Safety glasses
A fixture box is essentially the housing unit for an electrical device such as a light. If you want to add new light or change the current exterior lighting, then a fixture box may need to be installed. Many electrical jobs require the aid of an electrician but replacing or adding a fixture box is not that difficult of a job to complete. The following article will show you how you can install an exterior light fixture box yourself.
Step 1 - Pick the Location
Where you place the new fixture box is important because you need it to be close to wires and studs or joists. The best location is where or close by where a current lighting fixture is installed. Use your stud finder to locate the studs in the exterior wall or the joists. The voltage meter will be able to detect the electrical current through wires close to the surface. Use your chalk pencil to mark the studs. Look at your fixture box and measure its dimensions. With these in hand you can plot the area where the fixture box will be installed. Use the tape measure and the dimensions of the fixture box and draw the diameter of the fixture box onto the wall between the marks you made previously.
Step 2 - Safety
When working around anything involving electricity, you need to take precautions in order to avoid injury. Now that you know where the fixture box will be placed, you will need to turn off the electricity to that section. Make sure to wear safety glasses as well as to use your stud finder and voltage meter so you can make sure you will be consistent in your installation process.
Step 3 - Cutting the Hole
Use a hole drilling bit that is slightly larger than the fixture box you are installing. Center the hole drill bit between the studs and over the simple diagram you drew in Step 1. Apply firm pressure to the handle of the drill while your other hand holds the shaft firmly in order to keep the drill steady. Go slowly and stop periodically to check your depth. Continue until you penetrate the inside of the outer wall. Remove the circular piece you cut.
Step 4 - Installing the Fixture Box
Cut the positive and negative wires inside the wall and strip away the plastic casing. Cut and remove the casing around the wire for the new lighting fixture. Connect the wire to the wires within in the wall and place the wire caps on them. Pull the wire out of the hole and through the holes in the bottom of the fixture box. Place the fixture box inside the hole and screw it in place. Depending on the fixture box you are using, you may have to use brackets or can screw directly to the joists or studs. You can now finish installing your lighting fixture and then insulating the hole.
