How to Install an Upflush Toilet
what you'll need
- Saniflo toilet
- Adjustable wrench
- Screwdrivers
- Carpentry tools
- Measuring tape
- Assorted wrenches
- Level
- Discharge hose
- PVC saw
For those who have bathrooms functioning in the basement of the house or at any similar level that is lower than the average ground and above-ground level of most rooms in the house, the bathroom plumbing system can prove to be a challenge which is why an upflush toilet is what you may need. Flushing especially becomes a problem as most plumbing systems are not equipped to take into account specially located bathrooms. In such cases since it isn’t practically possible or sensible to rework the entire plumbing system of the house to meet the needs of a functioning household, the best option in this case is to install an Up-flush toilet. One of the best options to pick from is the Saniflo up-flush toilet which is the most developed of its kind in the market and comes with a range of features. Learning how to install an up-flush toilet in the house is an easy step-by-step process that can be undertaken by almost anybody and doesn’t need more than a day to get the job done.
Step 1: Preparation Process
The first step in the process involves doing all the preparation work for installing the toilet. The first step is to choose the location of the toilet and take down the measurements of the spot precisely. When one is marking the spot out it is important to take into consideration that a discharge hose, a water supply pipe and an electrical unit will all have to be affixed in the proximity of the toilet. The spot should be chosen keeping in mind the space needs of all these. The measurements have to be made accurately as even the smallest discrepancy can cause problems during and post installation.
Step 2: Placing the Toilet
Placing the toilet correctly is of the utmost importance as once the toilet is in use the water inside the system will add to its weight exponentially. Adjustments cannot be made later without disturbing the system hence it is imperative to position it correctly at the onset.
Step 3: Fixing Utility Cables
The toilet unit will need to have some standard utility cables affixed to it. This includes the power chord and the water pipe. The power chord will have to be fitted into a socket in the wall while the water pipe from the water systems of the house will have to be fixed in the appropriate valve.
Step 4: Fixing the Discharge Hose
The discharge hose will have to travel from the up-flush toilet to the upper levels of the house where it will combine with the main draining system of the house. The Saniflo unit comes with a special backflow valve which will take care of the direction of flow. While fixing the discharge hose try to ensure as much horizontal and diagonal placement as one can because vertical pipe systems usually experience common problems such as blockage and drainage.
