How to Install Boat Carpet
what you'll need
- Marine carpet
- Adhesive
- Tape measure
- Knife
- Roller
- Scraper
- Trowel
- Mineral spirits
- Rag
Installing boat carpet is a job that can considerably change the look of your boat. In order to do this, you are going to need to be able to pay attention to detail and go through some hard work. Here are the basics of how to install boat carpet successfully.
Step 1--Measure the Area
The first thing that you need to do is get the appropriate measurements for the space. Take your tape measure and get the dimensions of your boat. You need to be as detailed as possible so that you can order the right size of carpet.
Step 2--Get Materials
In order to install carpet on your boat, you are going to need to make sure that you get the right type of material. Visit a carpet store and order marine carpet. You also need to make sure that you order the appropriate type of glue for the job. You need to order to glue that can be used on a boat. Not every type of carpet glue can be used outside in wet areas. Allow approximately 1 to 2 weeks to get your carpet as most carpet stores do not keep many styles of marine carpet in stock.
Step 3--Remove Old Carpet
The next thing that you will need to do is remove the old carpet. Many times, this can be a very difficult portion of the job. You are going to need to use a scraper to take up the old carpet. The adhesive can be difficult to remove and you will have to scrape hard in most cases. Once you have the carpet up, you should do your best to clean up all of the old adhesive. You may want to try using mineral spirits and a rag in order to get the old adhesive off.
Step 4--Lay Out the Carpet
You will then want to lay out the carpet in order to make sure that it fits. Lay it down and check to see if there are any gaps in coverage around the edge.
Step 5--Spread the Adhesive
At this point, you should be ready to start installing. Pull up half of the carpet that is laid on the boat. Use your trowel and apply some of the carpet adhesive onto the deck of the boat. Make sure that you get plenty of adhesive on the surface and apply it evenly.
Step 6--Lay the Carpet
Then you will want to take the part that was pulled up and press it down into the adhesive.
Step 7--Spread More Adhesive
Then pull up the other portion of carpet that does not have adhesive under it. Use your trowel and apply some adhesive to this portion of the boat.
Step 8--Lay the Rest of the Carpet
Then take the remaining piece of carpet and press it down into the adhesive. At this point, you will want to take a flooring roller and roll it over the top of the carpet to get a good adhesion to the deck.
Step 9--Trim the Edges
Take your utility knife and use it to trim around the outside of the carpet. Remove all of the excess carpet and you should be done.
