Login Error
Close
How to Install Double Curtain Rods
by DoItYourself Staff
what you'll need
  • Tape measure
  • Pencil
  • Level
  • Double curtain rod mounting brackets
  • 1-inch screws
  • Phillips screw driver
  • 2 curtain rods with 4 endcaps
  • 2 sets of curtains
Double curtain rods allows you to hang two layers of curtains—a popular contemporary style of window dressing that gives a two-dimensional effect. Usually, the under layer is a light, thin material, allowing soft light into the room. The top layer is a thicker, more decorative fabric. This can make your room look elegant and allow for various styles of hangings according to your artistic tastes. The best part is that you don’t need to hire a professional to install them: this task can be mastered by even the most un-handy home-owners in just 20 minutes.
Optional
  • stud-finder
  • Wall anchors
  • Ladder
Step 1 – Decide Where to Put Your Brackets
The higher you place the brackets, the more spacious your room will appear. A general rule of thumb is to install the brackets 4 inches above the top of the window frame. They should also be 2-3 inches out from the sides of the window frame so that the rods will hang a little over the edges. This causes the illusion of a wider window.
Step 2 – Mark Your Bracket Placement
Use your level to lightly draw horizontal lines where you’ve decided to install each bracket, ensuring that the brackets will line up evenly with each other. Hold the first bracket up and mark on the wall where the screw holes are. Do the same for the other.
Step 3 – Mount Your Brackets
You may use wall anchors or drywall screws first if you are not screwing your bracket into a stud. If this is the case, screw them into the screw marks you have made on the wall. This will increase the installation’s strength. Next, line your bracket back on the wall and screw the top screw through the bracket hole into the wall (or into the wall anchors). Do the same for the bottom screw. Erase pencil marks. (Note: Longer windows may require three or more brackets to prevent sagging in the middle of the rods.)
Step 4 – Hang the Curtains
Once the brackets are mounted, put the curtains on the rod that will be closest to the wall. If your curtain rods are different thicknesses, the thinner one is meant for the back because traditionally they carry the light, shear drapes. Position the rod on the bracket and use a level to make sure that it is hanging straight. Do the same for the front curtains. Don’t forget to put the end caps on the rods. For a more appealing look, you can put decorative finals on the front rod and end caps on the back.
If you have chosen to hang a see-through white curtain for the first layer, you can now enjoy sunlight in your room without losing privacy. Also, small touches of color in your room that add tremendous value to your home.
 forum activity
