How to Install Drain and Supply Lines to a Clawfoot Tub
what you'll need
- Clawfoot tub
- Drain attachment
- Water supply lines
- Screwdriver and pliers
A clawfoot tub is a type of bath tub whose feet resemble that of an animal with a clawfoot. Aside from that, a clawfoot tub is simply a bathtub. When installing a clawfoot tub or any other type of bathtub, you will need to install the drain attachment and supply lines for the water. If you are simply replacing an existing bathtub with your new clawfoot tub, the supply lines for water will already be in place. It is simply a matter of installing the drain and connecting the existing lines to the tub.
This article discusses the process for installing drain and supply lines to your clawfoot tub. This includes the tools, materials and steps necessary to complete this project.
Step 1: Purchase Materials
At a kitchen and bath store or home improvement center you need to purchase the replacement or new clawfoot tub and the necessary accessories for the drain and water supply line. Prior to this purchase you will need to make sure that the existing bath tub has been removed and the supply lines have been exposed in order to make the new connection.
Working with the installation of a bathtub is not work that you can do alone due to the mere fact that bathtubs are extremely heavy. You need to have at least one other person working with you. You should also have a weight belt in order to prevent any strains to your back when working with the clawfoot bathtub. If possible, have the retailer that you purchase the tub from deliver and place it in order to make the installation easier for you to accomplish.
Step 2: Attach the Drain
You will need to take the drain accessories that you purchased for the clawfoot tub. The drain should consist of a strainer and a tube or pipe that will connect to the floor pipe. Position the bathtub over the drain opening for the bathtub and attach the strainer cover. This will complete the installation of the drain to your clawfoot bath tub.
Step 3: Attach the Water Supply Lines
The water supply lines for your clawfoot tub will need to be installed after the drain has been connected. The water supply lines will run to the faucet and hot and cold levers. To install the water supply lines, check the existing lines to see if they will connect to the threading found with the clawfoot tub. If necessary you may need to connect an adapter in order to make the connection work. With the adapters in place, hook up the faucet to the supply line. Before setting the faucet in place, turn the water valve on to the bath tub and test the faucet to see if they are working properly.
Step 4: Connect the Faucet
Once you have successfully tested the water supply lines for the clawfoot tub, connect the faucet and you are ready to use your clawfoot tub.
