How to Install Drywall in the Garage
Putting drywall in the garage is reasonably easy. Drywall is a product that is primarily made from gypsum with heavy paper on the two sides. It is an inexpensive material that can be nailed or screwed down. Drywall can be painted and have wallpaper put onto it. So here are a few simple instructions on how to install drywall to the garage.
Tools and Instructions
- Utility knife
- Drywall saw
- Keyhole saw
- Drill
- Measuring tape
- Straight edge
- Chalk line
- Screw gun
- Hammer
- Drywall screws
- Drywall nails
- Dust mask
- Taping knife 6-inches long
- Taping knife 12-inches long
- Drywall
- Drywall tape
- Joint compound
- Fine grit sandpaper
Step 1: Finishing Necessary Work Before Drywall Installation Begins
Before you can begin the installation of drywall in the garage, you must make sure that all the insulation, plumbing and electrical work that needs to be done is finished.
Step 2: Marking the Wall Studs
Indicate the location of the wall studs by placing a mark on the ceiling and floor. Having the marks in these places will make it easy to find them when you to start installing the drywall to the walls.
Step 3: Starting the Installation
Lay some scrap pieces of drywall on the floor. When you begin the installation of the drywall, start in a corner. Sit the sheet of drywall onto the piece of scrap and then butt the drywall in the corner. Make sure the opposite end is on the center of one of the wall studs. You are able to install the sheets of drywall horizontally or vertically. A lot of professionals install the sheets horizontally as this avoids joints along the center of the wall.
Step 4: Attaching the Drywall to the Garage
Attaching the drywall to the garage is not very hard. First, attach the sheet of drywall with the drywall screws or drywall nails in a few places, just to hold it. Once that is done, its time to fully attach the sheet of drywall. To do this, start in the corner again and press the sheet of drywall hard into the wall studs. Place the screws or nails every 6 inches along the studs, and the sheet of drywall will be attached to the wall.
Step 5: Finishing the Attachment of Drywall to the Garage
Now that you have the first sheet in, continue attaching the sheets of drywall to the garage around to the lower half of the wall and making sure that the sheets are butted tightly against the one before. Once you have finished the lower half of the wall it's time to do the top half of the wall. This is done the same way, by starting in a corner and working your way around the room.
Step 6: Doing the Drywall Joints
Use the 6-inch taping knife to apply a light covering of joint compound to the joints. Place drywall tape over the compound. Press the drywall tape onto the compound and make it as smooth as possible, making sure to remove any air bubbles. Running the knife on the tape will help press the tape into compound. Now cover the tape with more joint compound. Let the compound dry overnight. Once the compound has dried, you will sand the compound till smooth. This will provide a smooth surface for painting your drywall in the garage.
