Login Error
Close
How to Install Faux Tin Ceiling Tiles
by DoItYourself Staff
what you'll need
  • Faux Tin Ceiling Tiles
  • Adhesive
  • Chalk Line
  • Screwdriver
  • Measuring Tape
  • Hammer
  • Cutter or Razor Knife
  • Vacuum Cleaner
  • Ladder
  • Caulking Gun
  • Flat Knife
  • Straight Edge Ruler
Faux tin ceiling tiles add an aesthetic dimension to a room, giving it warmth and character. They are made of recycled paper, which makes it easy to install them; they do not exert extra weight on the ceiling and are at the same time eco friendly. Follow the easy steps described below in order to install faux tin ceiling tiles.
Step 1 – Measuring the Room and Purchasing the Tiles
Measure the ceiling of your room before purchasing your tiles. Buy a few extra in case of any mistake during installation. Purchase the tiles in a color that goes with your room. You can also paint your own tiles, but refer to manufacture specifications on details of whether the tiles can be painted or not.
Step 2 – Preparing the Ceiling Surface
Remove all fixtures from your ceiling such as vents, lights, fans etc; store them carefully as to not damage any delicate glass pieces. Before you do this make sure you turn off the circuit breakers at the breaker box to avoid getting electric shocks. Then use a vacuum cleaner and clean the ceiling, ridding it of dust or any popcorn coating.
Step 3 – Marking the Center of the Room
To mark the center of the room measure all 4 sides of the ceiling than divide it by 2. Once you have marked the center of the walls, from the center of opposite walls extend the chalk line and snap to get a line, do the same on the other walls and you will have a cross marking the center of the room.
Step 4 – Installing the Tiles
To install the tiles start with the center of the room, making sure that you have enough room on the sides to place half a tile at least. On the back side of your faux tin tile apply the adhesive in small dots using the flat knife. Don’t put too much adhesive and concentrate on the edges and the raised area. Some manufacturers recommend stapling or cement use, therefore read the instructions that come with the tiles.
Step 5 – Working Around the Edges and Fixtures
Where ever there is a fixture hole, you will have to either cut through the tile if it’s a small one (e.g. chandelier socket) or measure and cut the tiles accordingly, make sure you maintain the design of the tiles. For the edges, measure the distance between the attached tile and the wall and mark it on a tile. Use a knife to cut the tile to fit, then glue it on. Repeat until the edge gap is filled all the way around the ceiling. If necessary, you can use the hammer to gently but firmly put the tiles in place.
Step 6 – Caulking and Finishing Up
Once the entire room is done, use the caulking gun and caulk between the tiles and let it dry. Then place all the fixtures back in place and your job is done.
Step 7 – Precautions
This job may require help, whenever working with ceiling installations, make sure your ladder is stable. To test the adhesive, install a few tiles before proceeding to make sure that the hold is firm.
 forum activity
