Login Error
Close
How to Install Glass Bathroom Tiles on the Ceiling
by DoItYourself Staff
what you'll need
  • Substrate of your choice
  • Flexible mortar system
  • Grout
  • Notched trowel
  • Rubber Float
  • Sponge
Installing glass bathroom tiles on the ceiling is identical to installing tiles on the floor or wall. Here is a step by step guide to install glass bathroom tiles on the ceiling.
Step 1 – Attach Substrate
A substrate is a plane between the tile and the surface, or in this case, the ceiling. It is not recommended to install glass tiles directly to wood substrates. Measure and cut the substrate according to the size and shape of your ceiling. Then attach the substrate to the ceiling using drywall screws and a power drill. Be sure to drill into the ceiling beams.
Step 2 - Apply the Setting Materials
Any good grade and flexible mortar system is recommended. Mix the setting materials according to the manufacturers specifications. Using a 3/16” square-notched trowel, apply the setting materials to the substrate. Be sure to smooth out the trowel ridges using the flat edge of the trowel before setting the tile. Apply a thin layer of the setting material to the back of the tile as well.
Step 3 - Place the Tile Where It Needs to Go
The beveled edge of the tile is placed into the setting material and the larger area of the tile is facing you.  Leave about 1/16” between each tile. Gently press the tile into the setting material using a rubber float or equivalent tool. Be careful not to press down too hard as the setting material will begin to fill the gaps of the tile. Adjust tiles as needed to be sure the tiles are leveled and there is even spacing between tiles. Wipe down tiles with a damp sponge to remove excess setting material.
Step 4 - Grout the Tile
Wait twenty four hours before applying grout to tiles. Mix the grout according to the manufacturer’s specification. If the joints of the tiles range from 1/16” to 1/8”, then use a non sanded grout. If the joints are larger than 1/8” then use sanded grout. Following the manufacturer’s instructions grout the spaces between the tiles. Wipe down tiles with a damp sponge to remove excess grout. Be sure to use caulked joints on all inside corners where walls intersect.
Step 5 – Cut Glass Tiles When Necessary
Depending on the size and shape of your ceiling, your glass tile will need to be cut. It is recommended that you use a wet saw and a diamond rimmed blade for glass tiles. Push the tile into the blade slowly. Smooth the edge with a diamond hand pad, dressing stone, or tile blade. If you need to drill holes then use a diamond core bit and a power drill on low speed. To prevent the tile from cracking, continuously mist the tile and power bit. Drill holes 1/8” larger to prevent stress transfer to the tile if anything is being attached with anchoring bolts.
 forum activity
