How to Install Glass Mosaic Tiles Outside
what you'll need
- Trowel
- Thinset mortar
- Tile nippers
- Glass mosaic tiles
- Grout
- Grout sealer
- Grout float
- Sponge
- Cotton rag
Glass mosaic tiles can add a pleasant design to any outdoor table or patio. The bright and vivid colors, coupled with the abstract design, can really bring out the best to any exterior surface. You can choose from a variety of glass tiles at your favorite hardware or online store, and can integrate the different colors to any desired design theme for your home.
Porcelain or ceramic glass mosaic tiles are preferably used for outdoor applications, as these are more durable and can better resist the harsh elements of the weather. A little creativity is also a great asset when deciding to install glass mosaic tiles outside.
Step 1 – Preparation
Clean your intended canvass, to get rid of loose dirt, moisture and grease. If you plan to set glass mosaic tiles to a wooden table, make sure that the wood surface is sanded smooth, to allow maximum adhesion for the thinset mortar. When planning to follow a certain design pattern, it would be best to plot the template of your glass mosaic tile design before applying the mortar.
Step 2 – Apply Mortar
Use a trowel to apply a thin coat of thinset to the center of the intended area. This will make it easy to work outward, and accurately see the design pattern as you add more tiles. Remember to work on a small area at a time. You may use tile nippers to cut specific portions of the tile, depending on your intended design.
Step 3 – Press Glass Tiles to Set
Press 1 glass tile at a time to the thin set, leaving at least 1/8 of an inch between tiles. It is best to apply the tiles with a slight twisting motion, to ensure that the tile makes full contact with the mortar for maximum adhesion. After applying a few tiles to the intended area, pull 1 tile, to accurately determine if the back of the tile is covered with enough mortar. Apply more mortar directly on the back of the tile before setting back in place.
Step 4 – Let Dry
Leave the tiles to dry for at least 24 to 48 hours, before applying the grout. Remember to avoid any kind of foot traffic when working on a patio, to ensure a strong bond between the tiles and the mortar.
Step 5 – Add Grout
Use a grout float to thoroughly apply tile grout between cracks and crevices. Remember to use grout that is specified for outdoor or exterior use.
Step 6 – Remove Excess Grout
Use a wet sponge (preferably warm or tepid water) to remove excess grout from the surface of the glass mosaic tiles. Remember to remove excess grout before it completely dries. Failure to do so may result in a hazy, cloudy appearance. Thoroughly clean the area, until all traces of grout have been removed.
Step 7 – Apply Grout Sealer
It is best to apply 1 to 3 coats of grout sealer, after the grout has completely dried. Let the sealer dry, and polish the glass tiles with a dry cotton rag.
Glass mosaic tiles add a dose of color and design to an otherwise plain surface. Remember to work between temperatures of 50 to 75 degrees, to better facilitate the bonding process between the tiles and the mortar.
