How to Install Hurricane Shutters
what you'll need
- Local building code and permit
- Storm panel shutters
- Measuring tape
- Marker
- Notebook
- Electric drill with masonry bits
- 3- or 4-inch bolts
Hurricane shutters are a vital safety measure for those who reside in hurricane prone areas. They make all the difference in how well your home fairs in the event of a hurricane or other high winds. When properly installed, shutters can save you and your family from serious injuries, even death. They also significantly reduce the damage a hurricane can cause to your home and belongings. Most shutters are made from aluminum or plywood. Below is a guide on how to install storm panel shutters.
Step 1 – Obtain Local Building Code
This can be obtained from your local department of codes and permits. It will give you vital guidelines as to what type of shutters to install including recommended strength. Putting up the right shutters goes a long way in providing adequate safety in the event of a hurricane.
Step 2 – Take Frame Measurements
Place the tape measure at one point on the inside of the window frame, stretching it across to the other end. Mark both ends so as to get accurate shutter measurements. Measure the vertical length of the window as well. Bear in mind that the shutters should fit the wall openings for all areas to be covered rather than be placed over the wall openings. Proceed to take measurements for all windows and doors in a similar manner. Note down all measurements for required panels in a notebook.
Step 3 – Mark Holes for Drilling
Use a marker to mark the center points along each window and door frame. Do both horizontal and vertical markings. One marked center point should suffice for small or medium-sized windows. Larger windows and doors will require a couple more markings. These should be made along both the horizontal and vertical lengths of the window casings or door frames.
Step 4 – Drill Holes
Begin with one window and drill holes at all points marked. You’ll also need to drill a hole at each right angled point for all the windows. Do the same for the doors and skylights. Holes drilled should accommodate the bolts to be used.
Step 5 – Place the Shutters
Set the shutter in the frame for each window so that it fits in the opening precisely. This will prevent wind or debris from dislodging the shutters. About one inch should remain between the edge of the window or door frame and shutter surface.
Step 6 – Fit Bolts
Secure the shutters with bolts. Be sure to tighten the bolts in place. Work in a similar manner for all windows, doors and skylights.
Tips
- It is best that you install shutters which can resist winds with speed of at least 120 miles per hour.
- Install shutters over all doors, windows and skylights if you have any. This will assure maximum protection.
- Don’t wait until a hurricane warning before you install shutters. It is best to install well ahead of the hurricane season. A rushed job will probably give you less than satisfactory results.
