Login Error
Close
How To Install Outdoor Carpet
by DoItYourself Staff
what you'll need
  • Outdoor carpet
  • Double sided tape
  • Carpet roller
  • Utility Knife
  • Tape Measure
  • Straight Edge
  • Outdoor Adhesive
Wherever you want to enjoy outdoor living space, an outdoor carpet will provide a comfortable, soft flooring for your feet.
An outdoor carpet can add great value to the outdoor living space as it provides a great finished quality and makes it more like an actual room than a place outside. No longer in the 70's prickly green, outdoor carpet comes in a wide variety of colors and textures.
Step One
Prepare the installation area. Take the time to clean and scrub the area of any type of residue, oils, dirt, and other debris. If you have already removed a flooring of some kind, you will want to make sure all traces of any adhesive, mortar, or wood is completely removed and the surface is clean.
Step Two
Roll out the outdoor carpet over the area you are going to cover. Let is sit there for a few hours to expand and roll out to its real size. When carpeting is rolled up it tends to withdraw a little bit. Letting it expand will give you the true dimensions. If you try to cut it now you will be cutting it too soon and will end up with a loose fitting carpet.
Step Three
After the carpet has expanded, lay down the double sided tape along the perimeter of the area. Do not take the protective paper backing off of it yet. If you do, this will make the remaining process much harder.
Center the carpet on the area to that an equal amount of excess carpeting is along the perimeter. If any of the carpeting is going up the wall, make vertical cut to the edge of the carpeting area and cut down the side. Place a straightedge along the cut so you will make a straight cut.
At each corner make a V cut so the carpet will lay flat on the ground. You can trim around the corners.
Step Four
Pull back a part of the carpet and pull of the paper backing for the tape. Lay the outdoor carpet on the tape. Repeat this all the way around the carpet, as well as center tape pieces.
Make the outdoor carpet stick to the tape better by rolling a 50 pound roller over the carpeting. This will also flatten out the carpeting more. Once you are done, make a final trim with the utility knife.
Go over the edges of the out door carpet with outdoor clear adhesive so the corners will not start to curl up and keep water from leaking under neath it.
 forum activity
