cancel
Job type :
Zip Code :
community forums
comments
How To Install Patio Door Blinds
Patio door blinds are a simple and cost-effective way to add a modern flair to any room. One of the most popular uses for these blinds is to dress patio deck doors, as they afford easy accessibility or complete privacy with just the pull of a drawstring. They’re easy to install too. All you have to do is follow these easy steps:
Step 1: Measuring
Measure the width of the patio doors, starting from the top of the doors to the floor. Be careful to take into account any rugs or carpeting at the bottom and make sure to leave enough room for the mounting hardware which will be installed above the doors. Then measure the width of the doors from side to side and be sure to take any window moldings and the door handle into account. You may want to add a few inches on each side in order to fully cover the glass doors for maximum privacy. Blinds that just barely cover the width of patio doors are also not as aesthetically pleasing.
Step 2: Bracket Installation
All blinds will come with pre-packaged mounting hardware, usually consisting of wall anchors, screws, brackets and various other pieces depending on the type of blinds you choose. Follow the instructions included for attaching the mounting hardware to your wall. Most sets call for preliminary drilling for the anchors to which you will most likely screw in the brackets, installing them into the wall. Depending on the width and material of the blinds there will be two side brackets at either end of the head rail from which the blinds will hang. A third middle bracket may also be required to distribute the weight of the blinds evenly so they don’t come crashing to the floor.
Step 3: Head Rail Installation
Once your brackets are in place, you will mount the head rail evenly into the brackets, making sure the placement is even with the measurements of the width of your patio doors.
Step 4: Completion
Most blinds come with a rod or vane attachment which will enable a twist control over opening and closing the blinds whereas a chain or drawstring attachment which can slide the blinds open from the patio doors or shut, covering them from end to end. There will also be some finishing parts included, such as valances or decorative bracket attachments that are designed to conceal the working parts of the head rail and/or the mounting brackets themselves. These are aesthetic pieces which are highly recommended to enhance the beauty of your new blinds, leaving a beautiful look to your patio doors.
member comments
Related Articles
How to Clean Blinds
How to clean blinds and shades... read more
Varieties of Blinds and Shades
A guide to some varieties of shades and blinds, including standard roller shades, cellular shades,... read more
Horizontal Or Vertical Blinds For A Patio Door?
If you are looking for some ideas on a new look, horizontal or vertical blinds... read more
articles we like
Office Chair
The office chair, or desk chair is a familiar and constantly used part of the... read more
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Organic Rabbit and Deer Control for Your YardOrganic Rabbit and Deer Control for Your Yard
Do you enjoy wildlife such as rabbits and deer, you just don't like them munching... read more
sponsored articles of the day
diy centers
