How to Install Plastic Ceiling Tiles Part 2
what you'll need
- Staple gun
- Staples
- Stud finder
- Pine or fir furring strips
- Finish nails
- Hammer
- Pin nailer
- Pin nails
Although installing plastic ceiling tiles is normally a quick and easy home improvement project, some instances call for extra measures. For example, a really damaged or uneven ceiling may require the installation of furring strips to aid in the adherence of plastic ceiling tiles. Some adhesives may not hold tiles as firmly as others and may require the additional reinforcement application of a staple gun.
Step 1: Stapling Ceiling Tiles
Stapling ceiling tiles to a ceiling where adhesive alone will not hold the tiles is a great option for securing tiles. The tiles are hung as already mentioned, except for the addition of using staples and staple gun to hold them more securely in place.
Apply adhesive to tiles, position ceiling tiles in place as per the design outline and staple the outer tile flange to the ceiling. To start a pattern, cut off two flanges and place in a corner. Slide the next tile into the installed tile after applying adhesive, and staple it into place. Continue with this procedure of applying adhesive, placing tile and stapling until the entire ceiling has been tiled.
Step 2: Install Wood Furring Strips
Furring strips are an excellent way to compensate for damaged or very uneven ceilings. These pieces of ¾ by 1-1/2, pine or fir hardwood are nailed to the ceiling and provide a sturdy, even surface with which to attach plastic ceiling tiles.
Locate and mark the location of studs with the use of a stud finder. As a general rule, studs are separated every 16 or 24 inches. Mark all locations of studs and nail furring strips perpendicular to the studs (at right angles) beginning at the wall stud and working outward to the opposite wall. Locate furring strips far enough apart so that the tile flanges rest squarely on cross member furring strips. Carefully check that each furring strip is as flat and as level to the ceiling as possible. This will insure that all plastic ceiling tiles will also be installed flat and level.
Step 3: Attach Plastic Ceiling Tiles to Furring Strips
From here, assuming the measurements and levelness of the furring strips is correct, the rest of the work should go very smoothly. Although there are varying considerations on attaching ceiling tiles from this point, gluing and stapling will probably prove the most secure method. Apply a generous amount of adhesive to each tile and carefully position it in place. Staple at least 2 to 4 staples along each edge of the ceiling tile and work from one corner all around in a circular motion. This technique will ensure flatness during the stapling operation.
Step 4: Install Ceiling Molding
To complete the job, install either quarter or half-round molding to the borders between the ceiling tiles and the walls. For an even greater touch of elegance and sophistication, add exotic crown molding and finish with a stain or matching coat of enamel paint. Sanding lightly between coats will provide an even greater, more durable finish.
project steps
- Part 1
- Part 2
