How to Install Polycarbonate Panels in Your Greenhouse
what you'll need
- Polycarbonate Panel/roofing sheet
- Garden scissors/fine tooth saw
- Disk grinder/carborundum
- Aluminum tape
- Hand drill
- Silicone
- Stainless steel screw
Polycarbonate panels are used in two ways: as roofs and as walls. The Roofing sheet type of polycarbonate panels are available in different sizes, color and profile. The price of the panels depends on the kind of profile chosen. The most popular and commonly used type of profile is the corrugated roofing panel. The lifespan of polycarbonate panels depends on their quality. A roofing sheet may last from several weeks to a few months or even a lifetime. Researching leading manufacturers, highly recommended and positively reviewed panels should be able to help you in finding durable and long lasting roofing sheets. The following procedures provide a guide on polycarbonate panel roofing preparation and installation.
Panel Preparation
Step1: Roof Pitch
A lot of manufacturers recommend that a degree pitch around 1 in 5.7 is best for roofing projects. One example is a 10 degree pitch. For panels with lesser degree pitch, extra shielding is necessary. Panels with a low degree pitch tend to be vulnerable and easily degraded by weathering elements. Make sure to get the suggested pitch for your panel.
Step 2: Cutting
A polycarbonate panel can be cut using garden scissors or a fine tooth saw. The quality of the sheet affects how smoothly the scissors or the saw will go through it. The higher the quality of the panels, the easier cutting will be. Aside from the saw and the scissors, other methods of cutting the panels are by using a carborundum or a disk grinder. The grinder and the carborundum are used to cut several sheets of the panels at the same time. One drawback to using grinders and the carborundum is that cutting the panels all at the same time may result in the welding of the sheets by fusion. The edges of the cut panel should be covered in aluminum tape.
Step 3: Drilling
Prior to installation, all holes should already be drilled into the panels. Check for the manufacturer’s instructions on drilling holes and dimensions.
Installation
Step 1: Installation
After cutting the panels into their proper length, you should install the ‘f’ trim of the aluminum to the edge of the roof timbers. Do this by sliding the first panel of the roof into the channel of the ‘f’ trim. Seal using silicone.
Step 2: Fixing the Panel of the Roof
The roof panel should be installed on every timber support. Fix these two components using stainless steel screws.
Step 3: Work on the Next Roof Panel
The next roof panel should be clicked into position on the fixed panel. Make sure that the components are well placed and that the lengths are aligned. Repeat the same procedure for the following panels.
Note: Before fixing any of the panels, check for the ‘click strip’ of the panel. Each sheet slides easily when the strip is properly clicked. Refer regularly to the manual or manufacturer’s instructions to make sure that you are doing this correctly. It may be wise to ask for expert inspection after completion.
