How to Install Rain Gutters
what you'll need
- Rain gutters cut to the appropriate length
- Hacksaw
- Downspout
- Nail drill
- Chalk
- Ladder
- Lots of nails
Many homeowners ask how to install rain gutters. If your rain gutters need to be repaired after each downpour, then chances are that they are old and they need to be replaced. A gutter not only prevents damage by water to your windows and roof but also can act as an exterior house decoration if installed correctly with the right proportions. Most people will hire a professional to do it for them. However, note that the equipment that comes with fixing a gutter requires a number of professional tools and this is definitely not a one man job.
1. Mark the Outline of the Gutter
The first is to outline the gutter with chalk. Note that the gutter must be slightly sloped so that the water will flow. A slope should decline at least ¼ inch every 10 feet. Use the chalk to mark the location where the fascia bracket should be attached. The distance between each fascia bracket should be at least 16 inches. At areas where the downspout will be installed and turning of the gutters, use a turning gutter piece and the downspout as imaginary guidelines.
2. Attach the Fascia
After a clear planned outline of the gutter has been established, it is time to install the fascia. First thing to do is to attach the fascia. To install a fascia, drill a hole at least 2 inches deep into the raft tail while simultaneously pressing the fascia against the wall. Screw into the raft tails. Remember not to install the fascia in a straight line but in with a slope shape in mind.
3. Cut Gutter to Appropriate Length
After attaching all the fascias, it is time to install the rain gutters. Heavy equipment will be needed to cut the gutters to the appropriate length. Use heavy powered machines like a power miter fitted with a carbide blade or use a normal hacksaw to do the job. Needless to say, the machine will do the job faster. You will also need to cut the downspout hole at the lower end of the gutter.
4. Attach the Brackets
After cutting the gutter, brackets will need to be mounted on the gutters to prevent contraction during colder climates. Attach brackets about 5 inches from the 2 ends of the gutters and leave a distance of about 20 inches between each bracket within the gutter.
5. Mount the Gutters
Now it is time to mount the gutter onto the fascia. A helping hand will definitely be needed in lifting the gutter. A person will hold one end while the other person should hold the other end. Use a stepladder to reach the fascia and be careful. When mounting the gutter, pour a bit of water on the roof to see if the gutter can catch the water.
6. Attach the Downspout
To attach the downspout onto the wall, press the downspout against the wall and strap the aluminum straps onto the downspout and screw the straps onto the wall tightly.
7. Test
After finishing the gutter, be sure to test it. Pour some water to check if there is any leakage.
