Login Error
Close
How to Install Residential Electrical Wiring
by DoItYourself Staff
what you'll need
  • Pliers with insulated grip
  • Screwdriver with insulated grip
  • Voltage tester
  • Wire stripping tools
  • Casing stripping tools
  • Step ladder
  • Pencil
Installing residential electrical wiring is a task with many inherent risks, from the potential of electric shock while you’re doing the job to the risk of fire hazards if the job is poorly completed. However, if you’re an experienced do-it-yourselfer, you can still take on residential electrical wiring yourself with a little preparation and by making sure to always adhere to all safety standards. To learn more about how to install residential electrical wiring, read the simple steps outlined below.
Step 1 – Know Your Wires
Before you get started with your residential electrical wiring project, you need to know exactly what you’re dealing with. First of all, familiarize yourself with the different types of wires. The hot wires are typically the red and black wires, which conduct electricity from the circuit breaker to the electrical appliance. The white wire conducts the electricity out of the appliance and back into the circuit breaker. The ground wire, which is bare, usually doesn’t conduct any electricity, and is connected to the frame of the appliance. Remember that the ground wire and the white wire should never be connected.
When choosing the type of wire for your project, go for the thicker 12-2 electrical wire, which will carry more electricity and hence better serve modern appliances (like home entertainment systems, blow driers and computers) than the more traditional, lower-voltage 14-2 wires.
Step 2 – Get to Know Your Electrical Needs
Take a look at the plans for the rooms in which you need to install residential wiring. Figure out what your needs are going to be: how many and what types of appliances will you be running wires to? How many outlets will you need, and where will it be safe to place them? Where should you install your circuit breakers? The answers to these questions are specific to each house and family, and also depend on local codes. However, a general rule of thumb is to keep outlets at least 16 inches above the floor. Electrical switches, on the other hand, should be a minimum of 48 inches above the floor.
Step 3 – Plan Your Circuit Breakers Wisely
One of the most important parts of installing your own residential wiring is making sure that you will have enough voltage in the system. In addition to the big circuit breaker that connects your home to the electrical grid, each room will have at least one (and often more) circuit breaker as well. Although the legal standards for the number of circuit breakers and outlets you can have in a given home varies according to city and state, it is recommended to have a main circuit panel with at least 200 amps, and that has at least 40 locations for various circuit breakers throughout the house. Double check your local electricity codes to be sure.
 forum activity
