Login Error
Close
How To Install Roofing Paper
by DoItYourself Staff
what you'll need
  • Roof paper
  • Utility knife
  • Hammer with roofing nails
Installing roofing paper, or felt, is an essential element to construct a waterproof roofing system. It also act as a layer of insulation and water protection underneath roof shingles. Installation is not particularly tough when following these simple steps that will ensure a successful project.
What Is Roofing Paper or Felt?
The black rolls of roof paper or felt are made with asphalt and are normally available in rolls. The felt provides a layer of additional weather protection between the roofing finishing material (shingles, tiles) and the roof decking. The most common size width for rolls of roofing paper is 36 inches. It is commonly called 15lb paper. Many rolls are pre-striped allowing installers to keep a straight line when applying roll strips to the roof side by side. All drip edges along roof eaves, valley liners and flashing need to be installed before the roof paper layer is laid down. Only drip edge along roof rakes is installed after the paper.
Step 1 – Prep the Area
An assumption is made all materials are ordered based on the necessary measured requirements. Clean the decking as well as possible making sure it is moisture free with no debris. Make sure that all your roofing planks are secure with no nails protruding. Examine the entire decking area for any stray nails. A good tip is to run a flat head shovel along the surface are. If the shovel stops, you’ve found a protruding nails. Either pound it in or remove it. Make sure there are no splinters protruding as well. You’ll need to remove these and sand the area a bit to ensure a smooth roof installation.
Step 2 – Roll It Out
Start at the bottom edge of the roof and roll the paper out toward the peak.
Step 3 – Overhang Paper
Allow for a ½ inch overhang of paper down each side of the roof when unrolling the paper. This overhang will ensure that water will not enter underneath the paper getting trapped on top of the wood roof planks.
Step 4 – Over the Peak
Roll the roof paper up and over the peak
Step 5 – Secure Ends
Secure the outside edges with plastic capped roofing nails at 12-inch intervals.
Step 6 – Overlap Next Roll
When unrolling the next adjacent roll, allow for at least a two-inch overlap. Nail the two rolls in the overlap at 12-inch intervals. Repeat this until the entire roof is covered.
Step 7 – Trim Excess
Use a utility knife to trim all excess paper on the last pass.
Remember to always overlap roof paper at valley, ridges and hips by six inches. Cut a slit from the side of a paper roll to accommodate vent pipes. It's best to wear gloves and protective eyewear for safety purposes. Pay special attention to movements on top a roof. This is a very dangerous place to be and caution is always necessary.  Make sure all materials and tools sitting on top a roof are secure.
 forum activity
