How to Install Solar Power Windows
what you'll need
- Solar Power Windows
- Ladder
- Bucket
- Soap and Water
- Squeegee
- Plastic
- Tape
Solar power windows can save you a lot of money on your energy bill. This type of window actually doubles as a solar panel for the home. The are generally designed to keep cold air out of the home. If you're looking to improve your home and to make it a green home, then purchasing solar panel windows and installing them is a project you will want to do. Follow this guide to install your new solar power windows.
Step 1 - Understand What the Window Is
Before you install the new windows, you should understand what they do. Solar power windows are made with solar panels. The solar panels allow the passage of light through the window into the home. In addition, it also produces energy for the home. In 2008, scientists created a much more powerful solar paneled window for home use. Some research shows that these newer panels are 10 times more effective in drawing out energy for the home. If the home has a generator that can connect the solar power to produce energy, it will become much more efficient in energy production and less dependent upon traditional energy resources.
Step 2 - Remove Old Windows
Remove the old windows from the home. Tape up the hole that you just created, especially if you don't plan on installing the new windows just yet. You can usually pull out the old window by removing the window framing and the window sill. The window should just pop out.
Step 3 - Add the New Solar Window
Installing solar powered windows is similar to installing a regular window. It comes with a frame and a sash, a sill and any necessary hardware. Install the window from the outside of the home to the inside. It will usually pop into place. Be careful not to scratch the surface of the window, as the solar properties will reduce if the window is damaged. Add the sash, the sill and the frame. Nail into place.
Step 4 - Connect to the Generator
Follow the directions on your solar powered window. There will be instructions on how to appropriately connect the window to the solar generator. If you don't have a solar generator, you can skip this step. Understand that in order to harness the solar effects the windows create, you will need to have a generator or power pack that can change this energy from solar into usable energy for your home.
Step 5 - Clean the Window
Using a non-abrasive solution, clean your window. Usually water and newspaper works the best. Don't use razors or any other types of sharp objects on your window, because you will ruin the solar properties.
