How To Install Tin Ceiling Panels
what you'll need
- Tin ceiling panels
- L-shaped wall bracket
- Main runners
- Drop ceiling support wires
- Cross Ts
- Power drill
- Wood screws
- Tape measure
- Level
- Chalk line
The biggest aspect of installing tin ceiling panels is not the panels themselves but the support bracket and the runners and line that span the room. Once those elements are in place, installing the tin panels is a matter of dropping them into place. The grid system must be accurately installed and supported so that each panel fits perfectly into its allotted spot. Any miscalculation could result in an area too big or too small for a panel, and major adjustments will have to be made.
Step 1: Snap a Chalk Line
The first step is to determine the position of the L-shaped bracket that will install along the perimeter of every wall in the room. This bracket must be at least 4 inches below the bottom of the ceiling joists while allowing at least 7 1/2 feet of clearance between the floor and eventual drop ceiling. Make the appropriate marks on your walls. At one corner, secure the loose end of the chalk line at the mark level and stretch it to the other corner. Snap the line. Do this on all 4 walls.
Step 2: Install the L-Shaped Bracket
With the chalk lines as your guide, install the L-shaped bracket all around the room. Check the level periodically with the level tool to ensure it is straight. The bracket should have holes provided for the screws. Drill into studs if at all possible.
Step 3: Install Main Runners
The placement of the main runners will depend upon the size of the tiles. Most residential tiles are 2x2 feet. However, you will mark every 48 inches for the main runners. They will be subdivided with an additional connector halfway between each 48-inch section. Every 24 inches along each runner a cross T is installed. This allows it to intersect with the runner positioned perpendicularly.
Step 4: Support the Runners
At each cross point where the main runners meet, attach a length of wire and attach its other end to the joist above it. Make sure this does not pull the runners out of level. It needs to be of a precise and equal length all the way across the room.
Step 5: Install the Sub-Connectors
To accommodate the 2x2-foot panels, sub-connectors must be attached to sub-divide the 4-foot span between each runner. These require no extra support from the joists above. They need to be evenly placed to create 2 equal 24 inch sections so that each tile will fit accurately.
Step 6: Install the Tin Tiles
With the grid in place, begin to install the tiles. Pick up one tile, move it up between the runners of the grid and lower it back down flat upon the runners and sub-connectors. It should be a perfect fit. Ceiling tiles on the edge of the grid will rest partly on the L-shaped bracket.
The grid must be perfectly spaced in order for each tin ceiling tile to fit to specification. Properly spanned and supported, tin ceiling tiles will quite literally fall into place and need nothing further to secure them.
