Login Error
Close
How to Install Vinyl Flooring over Ceramic Tiling
by DoItYourself Staff
what you'll need
  • Vinyl
  • Self-leveling compound
  • Trowel
  • Knife
  • Straight edge
  • Pry bar
  • Caulk
  • Caulk gun
  • Tape measure
  • Seam sealer
  • Flooring roller
If you decide to install vinyl flooring, you will be able to get a durable and beautiful floor that can stand up to a lot of wear and tear. Vinyl flooring can be installed over a number of different subfloors including ceramic tile. Here are the basics of how to install vinyl flooring over ceramic tiling.
Step 1 - Prepare the Room
Before you can start installing vinyl over the top of ceramic tile, you need to make sure that the room is prepared. The first thing that you should do is use your pry bar to remove the baseboards from around the edge of the room. Then, you will need to smooth out the ceramic tile before you can lay the vinyl over the top of the. Ceramic tile has grout joints that are uneven and if you were to install the vinyl over the tile as is, you would see the grout joints under the vinyl.
Use self-leveling compound to fill in the grout joints. This could take a fair amount of self-leveling compound to accomplish this task. You will need to allow the self-leveling compound time to dry before you move on with the installation process.
Step 2 - Apply the Adhesive
The next part of the process involves applying the adhesive to the floor. With most vinyl adhesive, you will need to apply it with a trowel or with a roller. Once you apply the adhesive, you should allow it time to set up. The adhesive should be tacky to the touch but they should not come off on your fingers when you touch it. Spread the adhesive out over the floor so that it is thoroughly covered and evenly distributed.
Step 3 - Lay the Vinyl
After the adhesive has been applied to the floor, you need to lay the vinyl down into it. Unroll the sheet of vinyl and spread it out over the room. Press the vinyl down into the adhesive as firmly as possible.
Step 4 - Roll the Vinyl
At this point, you need to roll the vinyl with a flooring roller. You should take the roller over the entire surface of the vinyl. This will remove any air from below the vinyl and make sure that the vinyl makes good contact with the adhesive.
Step 5 - Seams
If you have to do a seam between 2 pieces of vinyl, you need to cut the 2 edges with a utility knife and a straight edge. Once you put the 2 pieces of vinyl together, you need to use the appropriate type of seam sealer to attach the 2 pieces together. This will keep the seam from coming apart down the road.
Step 6 - Finishing Up
You should then allow a few hours for the adhesive to dry. You can also put a bead of caulk around the edge of the vinyl floor so that water cannot get under it. Then put your baseboards back on the walls.
 forum activity
