Keeping a mini fridge clean is an easy task as long as you know what to do. Mini fridges are often used in dorm rooms, in small apartments and in condos, as well as in many Master Suites or work-out rooms in a home. Here are some tips on how to keep a mini fridge clean and mold free.
Tools and Materials Needed:
- Work gloves or dish gloves
- Liquid detergent
- Dish rags
- Clean soft cloths
- Bucket of water
- Large towel
Step 1- Get Rid of Bad Food
Start by tossing away any old leftovers, fruits and veggies already gone bad. Mold tends to grow after a few days and can spread. Check bottles of dressings, pasta sauces and other condiments jars for mold growth.
Step 2- Protect Floor
Place a large towel at the foot of the mini fridge before beginning to clean. This will keep the kitchen floor or the area wherever the mini fridge is located free and clear of debris.
Step 3- Prepare Cleaning Solution
Squirt a small amount of liquid detergent into a bucket of warm water, dip dish rag in solution.
Step 4-Start Wiping
Wipe down all areas of the mini fridge with the soapy solution; push remaining food items aside or remove them.
Step 5- Be Sure to Dry
Use clean cloths to dry the wet areas inside of the mini fridge; if the areas remain wet, it can result in mold or damage areas of the mini fridge.
Step 6- Keeping the Temp Accurate
Keep the thermometer or control setting inside the mini fridge at a medium level. If it is too high, it will freeze up and if it is too low, items will spoil easily.
Keeping your mini fridge clean and mold-free is easy and with regular cleaning, it will remain perfect.
Questions of a Do It Yourself nature should be submitted to our
