How to Kill Mold in Carpet
what you'll need
- Eye protection/goggles
- Rubber gloves
- Bandanna or mask
- Carpet cleaning machine
- Detergent
- Bleach/ammonia
- Mold testing Kit
If you suspect you may have mold in your carpet, you're going to want to kill it right away. Having mold in your carpet can cause many health complications such as wheezing, stuffy nose, eye or throat irritations, or even severe lung complications and allergic reactions. Killing mold in your carpet is not an easy task, but it's something you can do yourself. You'll save a lot of money in the process, without having to replace the carpets or call in a professional.
Step 1: Protection
When dealing with the mold you will need to protect your mouth, eyes and hands. Mold is very toxic, and while you're cleaning it's important that you don't get these toxins on your skin or breathe them in. Always use some kind of eye protection such as goggles, a bandanna or mask for your mouth and rubber gloves.
Step 2: Testing for Mold
Do a thorough mold test on your home to make sure it's not anywhere else beside the carpet. If the mold is in your HVAC system or some other part of your home, cleaning the carpets alone will be a waste of time. There are a few different ways to test for mold. You can buy a test kit that has a tape in it that you can put on surfaces and then send into a lab to check for mold. There are also kits that can check your air for mold so that you will know if it's in your HVAC system. The air test is the most expensive test you can do yourself, but still cheaper then hiring a professional to do the job for you.
Step 3: Cleaning the Carpet
There are a few things you can use on your carpet to get out the mold. You can use a dish washing detergent along with water in a rug shampoo machine, but a lot of times it takes something more aggressive. Using Lysol and water in the carpet cleaning machine or bleach and water should kill the mold. Make sure you don't mix the two. Use about 1 cup of Lysol or bleach to the bucket of water. Spray the carpet with the solution and let it set for 15 to 20 minutes and then vacuum all the dirt and mold out. Get all the water out of the carpet that you possibly can, because you don't want the moisture to cause even more mold. After you have vacuumed up all the water, you will want to either set up some fans and open windows. If you have access to a dehumidifier, this will finish getting out the moisture and hopefully leave your carpets mold free.
