How to Lay Concrete on Top of Formica
what you'll need
- Cardboard boxes for patterns
- Concrete board
- Concrete
- Table saw
- Nails
- Concrete sealant
Most new-build homes come with Formica counter tops as standard. You might want to lay a concrete counter top over the Formica surface. Formica surfaces will usually cost a thousand dollars to lay an entire kitchen, and granite fabrics can cost two or three thousand. Concrete counter tops, on the other hand, may cost as little as 500 dollars. Concrete can be shaped and molded to fit any kind of counter, and it can be styled to create a much more attractive appearance than any standard Formica tops.
Step 1: Measure the Counter Tops
Find a couple of large cardboard boxes. Refrigerator boxes should be suitable for this. Measure your Formica counter tops, and then lay your patterns on top of the counters. Cut them into the pattern of the Formica tops to ensure that the concrete will fit securely on top of the Formica.
Step 2: Cut the Concrete Board
Using the cardboard as a cut-out pattern, cut concrete board to the shape of the counter tops. You may need to use a power tool such as a table saw to cut the concrete boards into the right shape. While you are cutting the board, remember to include fittings and fixtures such as sinks and kitchen taps.
Step 3: Mix Your Concrete
For a darker counter top, mix high-strength concrete with reinforced fiber. For a lighter counter top, use something such as a white Portland cement. You will be able to find both of these mixes in your local home improvement store. You should try around one box of concrete dye for every bag of cement.
Step 4: Cover the Boards
Once the concrete is mixed, cover the concrete board with it, and pound on the covers to ensure that air bubbles are eliminated. Allow the counter tops to dry. Once they are dried, pry the concrete tops from the board molds, and lay them over the Formica. Screw, or use construction adhesive over the edges of the Formica counter tops.
Step 5: Install the Concrete
Set the concrete in place, and then add a deep-penetrating concrete seal. These can be found at good masonry stores, home improvement stores or from professional suppliers. This sealant is necessary to prevent water and moisture from penetrating the concrete.
Here are some tips for maintaining or improving your concrete counter top, once it's been sealed:
- You can add features such as tile backsplash placements.
- For a high shine on the concrete, use a car wax. You can repeat the waxing once every six months or so.
- Check the Formica regularly for cracking or splitting. If these signs occur, you will need to remove the concrete counter tops, get rid of the Formica and replace with other counter tops.
- Make sure that the the gaps between the counter tops are cleaned regularly, to avoid dirt and dust build-up.
- You can also use polish on the concrete to get a good shine and clean the tops.
