Login Error
Close
How to Lay Sod in 10 Steps
by DoItYourself Staff
what you'll need
  • Garden fork or spade
  • Garden rake
  • Hose
  • Pre-turf fertilizer
Planting sod correctly is essential, especially as your new lawn is the centerpiece of your garden and can increase the curb appeal of your home. The following article explains how to lay sod in just 10 easy steps.
Step 1 – Preparation
Prepare your soil to encourage a fast, deep rooting process. Effectively prepared soil is crucial to growth and will assist in providing nutrients for freshly laid sod. Add a good quality topsoil to existing soil to help promote growth.
Soil should be loosely turned over to a depth of 4 to 6 inches. This can be done with a garden fork or spade although a rotovator will provide a more consistent depth and is ideal for working in any topsoil you have added yourself.
Step 2 – Clear Debris
Make sure the area to be covered is free from sticks, stones, weeds and heavily clogged soil. A rake will make this much easier. Pull all debris back to one corner of the prepared area so you can easily dispose of it.
Step 3 – Compact the Ground
Lightly compact the soil by firmly walking up and down the entire area. Then repeat the process at a perpendicular angle to further compact the ground.
Step 4 – Till the Soil
Using the garden rake, lightly drag the soil to produce a fine till. Visually inspect the entire area to make sure that the surface is level.
Step 5 – Water the Prepared Surface
Heavily water the prepared surface at least 36 hours before laying sod. This will provide sufficient moisture to help the sod root quickly and help the prepared soil to settle.
Step 6 – Apply a Fertilizer
Pre-turf fertilizer provides many essential nutrients. Apply a liberal spreading immediately before laying sod.
Step 7 – Lay the Sod
Begin laying sod down a straight edge of the prepared area, and continue until a single row is complete. Make sure that individual sods are closely butted together, but do not allow them to overlap.
Once the first row is finished, start the second row with a half cut of sod before working down alongside the first row. This type of brickwork pattern promotes stronger bonding as the sod roots into the soil. Finish the second row with the other half cut of sod.
Start the third row with a full cut of sod, and repeat this pattern until you have covered the entire prepared area.
Step 8 – Tamper the Edges
Hold the rake vertically and firmly push down on all joining edges of sod. Never use a roller, and don’t be tempted to stretch sod by tugging it. If you are concerned about any gaps, simply fill them with a little topsoil and tamp down.
Step 9 – Watering
Water sod as soon as it is laid. Give a thorough soaking for the next 5 to 7 days until firm rooting is established. Water early in the morning or in the cooler part of the evening. Watering sod during the hottest part of the day can cause grass to burn due to the magnification of light rays through the water itself.
Step 10 – Cutting
Cut the sod about a week after laying. Never cut off more than 1/3 of length in any one cut. Early cutting helps to ward of disease.  The first few cuts should just ‘top’ the lawn. Use a lightweight mower until the sods have completely bedded in.
You may also feed the lawn any time after the first cut has taken place.
 forum activity
