Login Error
Close
How to Locate Exterior Wall Studs
by DoItYourself Staff
what you'll need
  • A magnetic or electric stud finder
If you're currently searching for exterior wall studs in your home's walls, there are several different methods of locating them. Fortunately, each of these methods are simple and highly effective, and can be successfully performed by any household handyman. So if you're on the hunt for studs in your home's exterior walls, simply read on to learn everything you'll need to know.
Step 1 - Tap Your Walls
For those of us who don't have access to either an electric or magnetic stud finder, the old-fashioned wall-tapping method is the way to go. Using your fist, tap on your home's walls and listen intently for a solid sound. This type of sound usually indicates the presence of a wall stud.
Step 2 - Use a Magnetic Stud Finder
If you have access to a magnetic stud finder, begin this step by running the device across your wall of choice and wait for it to indicate the presence of a wall stud. This type of stud finder will locate metal studs, as well as metal construction materials that secure other kinds of wall studs in place.
Step 3 - Use an Electric Stud Finder
An electric stud finder, which measures a wall's density, is arguably the best tool for locating wall studs. If you own this type of stud finder, run it across your wall of choice and wait for it to make a sound that indicates the presence of a solid, potentially stud-laden area.
 forum activity
